20 Most Recent Pioneer VSX-456 Receiver Questions & Answers
manual
0answers
0answers
Need to know how to
Have you looked at the manual? It's basic hook-up.
Any source's Outs go to Ins on the receiver.
Tape recorders attach to tape loops (outs to ins).
Digital sources will not appear at analog outputs.
5/22/2011 11:30:16 AM • Pioneer VSX-456... • Answered on May 22, 2011
Pioneer vsx 456 unit
Usually when most units happen to have this sort of problem it is mostly as a result of the battery in the remote controller being bad. Due to the bad state of the battery it is unable to power the controller therefore the controller is unable to power the unit. First trouble shooting tip will be to chech the battery in the remote control.
If the battery happens to be fine then there is a probability the remote controller is bad try switching the unit from standby mode manually this you can do by pressing any of the function buttons on the unit.
If this still does not work then apparently the problem is with the power pack which is contained inside the unit. if it receives power the unit will come on but if it is faulty and does not distribute the power properly then the unit could be stuck on standby. In this case you need an expert to examine and work on the unit.
Hope this solution has been helpful?
2/12/2011 8:29:38 PM • Pioneer VSX-456... • Answered on Feb 12, 2011
Trying to connect a Plasma
What you need to do is connect the HDMI from your source(SAT, Cable box or DVD) directly to your tv. Then, connect audio from that same source down to your pioneer receiver.
Good Luck
1/7/2011 8:24:53 PM • Pioneer VSX-456... • Answered on Jan 07, 2011
I am getting an
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
6/3/2010 6:24:35 PM • Pioneer VSX-456... • Answered on Jun 03, 2010
Turned stereo on and turned volume all the way up
assuming same issue does not happen if you connect a headphone to your receiver - can you check your speakers' connections - it should be straight not crossed for each and in case speakers are properly connected to your receiver - can you test the audio/sound with internal test audio rather than connected device (ie player) - if this is ok and there is no sound/audio volume settings on connected device - change the input the device connected and test again.
9/1/2009 8:36:19 PM • Pioneer VSX-456... • Answered on Sep 01, 2009
I get no sound output from my vsx-456, everything turns on
check mute or attenuation function
8/13/2009 3:23:58 AM • Pioneer VSX-456... • Answered on Aug 13, 2009
Pioneer vsx 456 shuts down
Check air flow most have a heat overload
7/21/2009 12:12:15 AM • Pioneer VSX-456... • Answered on Jul 21, 2009
0answers
VSX-456
Be the first to answer 7/19/2009 9:39:51 AM • Pioneer VSX-456... • Posted on Jul 19, 2009Be the first to answer
22 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
pioneer vsx 456 unit
  • Audio Players & Recorders
