20 Most Recent Pioneer VSX-815-K Receiver Questions & Answers
3answers
My pioneer vsx 815 amplifier has a flashing blue
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
1/2/2024 3:15:44 PM • Pioneer... • Answered on Jan 02, 2024
My pioneer vsx-815k receiver goes to protect mode and now when i try to reset it there´s no red standby light on and theres no fuse blow, what shoud i check? to turn it on?
I would think that the cost to replace would not make fixing this an option.
12/29/2016 10:25:23 PM • Pioneer... • Answered on Dec 29, 2016
2answers
Pioneer manual repair
You have probably blown an internal fuse. You may find more information here: http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219098VSX815OperatingInstructions.pdf If you are inexperienced in electronics repair, you should take your unit to the nearest Pioneer service center.
5/19/2016 6:54:56 PM • Pioneer... • Answered on May 19, 2016
5answers
Vsx-815 steady blinking blue light
Hold "Enter" and "Advnc. Surrnd" buttons on receiver at the same time.
7/29/2015 4:55:37 PM • Pioneer... • Answered on Jul 29, 2015
0answers
PIONEER VSX815-K NO FUSES BLOWN BUT NO POWER
How do you know no fuses are blown - you have to check with a multimeter. Are you sure the outlet has power? If the fuses are fine and there is for sure power, then it may be getting power but the capacitors are shot or something else internally is blown. It sounds like it's probably beyond your scope and should be brought in to an electronics repair shop.
8/28/2011 8:27:43 PM • Pioneer... • Answered on Aug 28, 2011
Vsx-815h,power on hear the click
Hello
At first check does the amp tunes to radio stations and can you hear sound from it. Your amp has no HDMI input function. The setup may have changed to your DVD or Blu-Ray player. Without knowing the device you connected to it, it is difficult to point out the exact fault. Anyway , just try these as your amps' maual indicates.
The user manul of your set points out these reasons only for absence of sound with your amp.
Go to the signal select setup and select "Auto" there. If it is selected to AUTO mode when you input a digital signal or analogue signal, the set will detect it automatically.
check whether MUTE finction is ON. If it is ON, turn it to OFF.
Check the speaker select function.
OK
4/14/2011 3:16:15 PM • Pioneer... • Answered on Apr 14, 2011
Disply showing only 5.1 how
you have to have a 7.1 sound on the DVD in order for it to be detected. make sure to buy or rent a DVD that indicates on the back that it is recoreded in HD(X) sound or 7.1 sound. I hate to tell you, but there are not many that are recorded that way, there are a few that are 6.1 but the majority are 5.1 sound. you may be able to purchase a test DVD that will have various types of sounds on it as well as differnet videos to try, these disks are made to help people set up their HD sets and sound systems. big box stores like Best Buy etc may have one., or you could order online through a google search good luck
3/14/2011 11:00:16 AM • Pioneer... • Answered on Mar 14, 2011
Where do my subwoofer speaker wires get hooked up
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
12/10/2010 4:43:02 AM • Pioneer... • Answered on Dec 10, 2010
The volume control button on
most used button on your controller could be a victim of grime carefully take apart the controller and gently clean the pickups with an eraser or light alcohol based cleaning solution a little goes along way also flip the button pad and inspect for dirt ok soft drinks are often the culprit hope this helps
11/17/2010 8:26:55 PM • Pioneer... • Answered on Nov 17, 2010
Receiver will not switch to tv/dvd
can you scroll thru the inputs with the remote,and/or the input knob on the receiver.have you set up your inputs via the on screen menu?
7/6/2010 12:52:14 AM • Pioneer... • Answered on Jul 06, 2010
2answers
Receiver shuts down when setting volume above certain range.
disconnect all your speakers and if it still does it, yes, take it to service. if not, check all your speakers and wires. good luck
5/17/2010 1:56:39 AM • Pioneer... • Answered on May 17, 2010
Doesn't turn on
does it have the blue flashing light on the power button?
5/16/2010 9:51:55 PM • Pioneer... • Answered on May 16, 2010
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
5/16/2010 4:37:14 PM • Pioneer... • Answered on May 16, 2010
Pioneer VSX-815-K Receiver Logo
44 questions posted
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Audio Players & Recorders
Most Popular Question
pioneer vsx 815 amplifier flashing blue
  • Audio Players & Recorders
