20 Most Recent
Pioneer CT-W103 Single Cassette Deck Questions & Answers
CT-W103 play back is to fast
You may have some broken tape wrapped around the capstan. The capstan is the small silver post that rotates when the tape is playing. A rubber roller presses the tape against the capstan. This silver post needs to be just that - silver. If it has any brown tape or goop on it, clean off the tape or goop with a small knife. Then follow up with nail polish remover [acetone]. Don't use alcohol because that will harden the rubber roller over time.
I need to know how
Once again since nobody will actually do the research and give you guys the correct information I will provide the answers to all the incorrect guesses, misleading page references and no responses form our "Pros". I have a copy of the exploded view showing the belts and part numbers to order or compare to. Mt search took me less than a minute to find.
Belt replacement pioneer cassette
These decks don't just need a replacement belt but a lot of other things. They are not often worth repairing but that is left to the owner and how much they want to spend to get it fixed.
I need a complet set
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
Where can iu get the
You can v=get the belts from Marrs but there are often times no diagram other than the parts layout in the service manual.
How to reset a pioneer vsx 456 receiver
To reset your Pioneer VSX-456 receiver, you can try the following steps:
Turn off the receiver.
Press and hold the "Enter" button and the "On/Standby" button simultaneously until "Reset" and "No" appears on your display.
Use the "Preset" arrow buttons to make the display say "Reset" and "Yes" .
Press the "Enter" button on the front panel to confirm .
If this does not work, you can also try unplugging all external devices before beginning the system reset. Switch the receiver into standby mode by holding down "Band" and then pressing and holding the "Standby/On" button for about two seconds. When you see "Reset?" on the display, press the "Preset" arrow buttons to make it say "Yes." Finally, press the "Enter" button on the front panel to confirm .
