20 Most Recent
EliteGroup P4S5A/DX Motherboard Questions & Answers
Switch Wiring for P4S5A/DX+
go here download manual http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
I need the manual of
http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5a51aeng.zip
There you have the manual, if you need to download anything from ecs justo go to http://www.ecsusa.com
and select download.
Best regards
May computer is hang-up after
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Connection diagram plug the USB ports to the EliteGroup P4S5A/DX+
Here is a link to the manual for your motherboard. It should show you how to connect your usb cables.
Hope this helps.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=39&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
How to install audio driver for P4S5A DX+ ?
According to the Elite site your audio driver is:
C-Media CMI973x/9761A Audio Driver
The link to the download page is:
P4S5A/DX+ Downloads
The audio driver is at the bottom. Click on a download server closest to you. The downloaded file is a .zip file. You can Save it to your desktop, but then must extract it to it's full size and format. (.exe file) Once extracted you can run (double-click) the file to install the driver on your system.
Thanks for using Fixya.
P4S5A/DX Motherboard ethernet connection
It should have an ethernet port!! its right next to the USB ports, check you have the right cable
get the manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=38&DetailName=Manual&DetailDesc=P4S5A/DX%20%20(V5.1A)&CategoryID=1&MenuID=82&LanID=0
kind regards and please don't forget to rate us
EliteGroup P4S5A - Motherboard - ATX - SiS645 - Socket 478 - UDMA100
try to do the ff:
before you replace your Mainboard.
1.did you try to set your bios to default settings ,then save and restart.
2. try to clean your memory and memory slots ,
3.try to remove your other hardware except the video card and restart your unit.
4.try to reformat your hardisk.
All i need is a manual
Why can't you download the manual? Should be in .pdf format which I am sure you can read with a mac.
No power supply activity
check all wiring connections going to the board, also check that the bios jumper is not set to clear bios.
