20 Most Recent EliteGroup K7VZA Motherboard Questions & Answers
ECS K7VZA still Beep Alarm
Look for blown capacitors. Replace them.
8/7/2010 4:31:35 AM • EliteGroup K7VZA... • Answered on Aug 07, 2010
2answers
Checksum Error after Bios Upgrade K7VZA
Have you tried resetting the CMOS? Often, after upgrading BIOS you need to clear the CMOS and re-setup to handle the new features. You should have a jumper to clear CMOS, or you can remove the power from the system and remove the battery for a few seconds to clear it.
Let me know if this clears up your issue.
9/22/2009 3:40:25 AM • EliteGroup K7VZA... • Answered on Sep 22, 2009
I have a K7VZA motherboard when i turn power on
The very first thing you need to do is unplug all drives inc power.
Now remove as many add in cards as you can without compromising the system.
Try to boot at that point.
If it boots re-connect each piece of hardware one at a time until you find one that causes a problem.
Double check that item for any issues and replaces if needed.
If you have had the fan off the cpu for any reason then you should have cleaned both the cooler fan underside and the top of the CPU and put fresh thermal grease made for that purpose on there. DO NOT use too much as that is almost as bad as too little.
Is the fan the correct type eg motherboard takes 3 pin and fan is 4 pin ?
Make sure it is connected to the CPU FAN pins on the board and not system fan.
If you have another computer and the fan can be removed from the cooler itself you could plug it into the system fan port of another computer to try it out.
under no circumstances should you run a system without the CPU cooler running as it could cause irreparable damage to the CPU
8/19/2009 12:39:09 AM • EliteGroup K7VZA... • Answered on Aug 19, 2009
Power problem i think
If there is no beep, even after removing RAM means you have faulty Motherboard and/or faulty Processor.
Try to reconnect CUP also clean the CPU socket on board and try to test without RAM, if you got long beep (RAM missing) then proceed further i.e. add RAM, HDD, CD/DVD etc step by step.
If didn't get any beep try to test with other motherboard/CPU to find which one is faluty.
Please post your feedback.
Thanks and Good Luck
Iqbal
8/18/2008 10:32:07 AM • EliteGroup K7VZA... • Answered on Aug 18, 2008
2answers
Disabling COMM ports
If you're pretty sure its your comm ports, boot up into your bios setup screen. (Tap Del while booting) Then go to the onboard devices page or any page that lists your com ports and change the property value to disabled.
Regards,
Worldvet
6/20/2008 12:25:13 AM • EliteGroup K7VZA... • Answered on Jun 20, 2008
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
0answers
LAPTOP l41sa1
Be the first to answer 6/9/2014 4:31:05 AM • EliteGroup... • Posted on Jun 09, 2014Be the first to answer
Check operator services nokia
http://www.nokia.com/us-en/?dcmpid=bmc-src-google.Brand
6/2/2014 3:49:19 AM • EliteGroup... • Answered on Jun 02, 2014
EliteGroup K7VZA Motherboard Logo
6 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
checksum error after bios upgrade k7vza
  • Computers & Internet
