20 Most Recent EliteGroup 848P-A V2.0 Motherboard Questions & Answers
Computer does a hard shut-down after a few minutes
Hard shutdown sounds more like it would be a ram issue, power supply issue or a overheat issue, i would make sure everything is re-seated, Remove ram/cpu and reinstall them,reapply thermal paste to the heatsink before reinstalling it to CPU, if you have more than 1 stick of ram, try it one at a time, might be one bad stick. if you have an extra power supply lying around try it as well, if not, most computer shops have power supply testers, or you can buy one for about $25. do each thing one at a time, so that if it starts working your not wondering what part did it.
i personally would lean more towards the powersupply, or a power issue, make sure there isnt anythign shorting out in the case or on the back of the motherboard. There could be an internal short in the power supply as well. they are designed to instantly power off if ANY kind of short is detected on any of the power wires going to any of the devices..
1/1/2011 5:19:52 PM • EliteGroup... • Answered on Jan 01, 2011
I bough memory for my
Hi
Thank you for your query
The memory is correct please can you try putting in only memory stick at a time and see if this problem occurs, it could be that one of the sticks could be faulty
Regards
Shauqat
9/26/2010 12:57:00 AM • EliteGroup... • Answered on Sep 26, 2010
5.1 sound from dvi/hdmi
OK, ASUS is the video card, and the MOBO is from ECS...Which makes great boards BTW, I've had one for about 4 years now, put it through hell, and it won't quit. Anyway. If you're trying to get sound from the asus...you may want to make sure your HDMI standards are compatible on both ends.There are at least 3 standards thatI know of, and the drivers may not support one or the other properly. Also, the asus website offers certain utilities for downloading.
1/6/2009 6:50:55 AM • EliteGroup... • Answered on Jan 06, 2009
2answers
Ecs 671t m3
The ECS website.
10/19/2018 1:20:10 PM • EliteGroup... • Answered on Oct 19, 2018
What is the basic code for html code for
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
5/11/2016 10:20:28 AM • EliteGroup... • Answered on May 11, 2016
Computer will not enter bios during boot
PRESS F2 or del if you have usb use a an adapter for a ps2 connector from the keyboard will probably help to set your bios settings maybe replace your backup battery when you have lost your settings.
2/14/2016 12:19:59 PM • EliteGroup... • Answered on Feb 14, 2016
Ecs 848p-a v1.0
The manufacturer's support page for this motherboard can be found at the following link http://www.ecs.com.tw/website2008/Product/Product_Detail.aspx?CategoryID=1&DetailID=361&DetailName=Feature&MenuID=24&LanID=0 Perhaps the answer to the question you have not asked is found there.
9/8/2015 6:14:13 AM • EliteGroup... • Answered on Sep 08, 2015
P4S5MG/GL+
A manual for this motherboard can be found at the following link http://download.ecs.com.tw/dlfileecs/manual/mb/eng/p4/p4s5mggl50eng.zip In the downloads section of the support for this board, there was no "Auto Setup Program". Downloads from the manufacturer for this motherboard can be found at the following link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=42&CategoryID=1&MenuID=18&LanID=0#fragment-Download
9/8/2015 6:11:13 AM • EliteGroup... • Answered on Sep 08, 2015
Where is the battery
If you are asking where the CMOS battery is located, you will need to firs provide the model number of the ECS EliteGroup motherboard. Here is a link to help you locate yours http://www.ecs.com.tw/extra/productinfo/MB.htm
9/8/2015 5:43:48 AM • EliteGroup... • Answered on Sep 08, 2015
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
8/15/2015 1:38:38 AM • EliteGroup... • Answered on Aug 15, 2015
I cannot find my administration key that is needed at the end of my installation of my motherboard. I cannot find the code in the box. Where is it?
Hi, Could you elaborate? I have never heard of this... unless you are talking about the Administrator password Windows asks for during install... which you can typically just leave blank and continue the install...
1/31/2015 8:52:47 AM • EliteGroup... • Answered on Jan 31, 2015
0answers
0answers
LAPTOP l41sa1
Be the first to answer 6/9/2014 4:31:05 AM • EliteGroup... • Posted on Jun 09, 2014Be the first to answer
Check operator services nokia
http://www.nokia.com/us-en/?dcmpid=bmc-src-google.Brand
6/2/2014 3:49:19 AM • EliteGroup... • Answered on Jun 02, 2014
My system utility cd for intel platform version's serie number is 83-150-306345. I need the Product key numbers
you do not need cd key for motherboard driver
5/27/2014 4:28:14 AM • EliteGroup... • Answered on May 27, 2014
EliteGroup 848P-A V2.0 Motherboard Logo
Popular Tags
5 questions posted
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • EliteGroup Computers & Internet
Most Popular Question
bough memory
  • Computers & Internet
