20 Most Recent
Technics SL-MC4 61-Disc CD Changer Questions & Answers
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
How do I play full random mode
on the remote push the random button twice. the first on will be random on the disc selected. when yoiu push it twice it's full random
Unit is locked
Take the 4 screws from the sides and the two in the top back of the unit. What has probably happened is that you have a cd laying on the bottom of the unit and the arm can not make the entire sweep.
cdt
Scratched cds
anything can be repaired . with enough money and time anyways..
I don't understand why the discs would be getting scratched though.... the only thing that touches the readable surface is a laser.
Maybe the unit is just dirty. Call a local repair shop and ask how much to clean it up... I had a CD jukebox with a 600 disc changer cleaned for under $100 not long ago.
Small cable with spring attached not attached to unit
The cable does run acroos those 4 rollers on the CD drive unit. The cable is staticly attached on the right side (unit facing you) of the carrier rack, routes under the lower rifght roller, up and outside of the top right roller, across and outside the top left roller, then down and inside the lower left roller.
From there, it routes across the carrier to a small hook (black plastic). Under that hook and then up to the spring.
I can send pictures if you need them. I have this same unit with a carrier that will not fully eject the CDs. I have been in this case more than once.
