20 Most Recent
Sony e-Book Reader Questions & Answers
How to unfreeze an ereader
Make sure you are trying to charge from a wall outlet rather than USB. Leave it plugged in overnight. After that try a soft reset -- press the RESET button with a paper clip or similar object and press power on.
I cant charge my e 705 ereader
What are you using to charge it? How old is your ereader?Are you using a usb cable to computer to charge? Or do you have an adapter that goes in the wall socket that connects to your usb cable.You may need a new usb cable, or depending on the age of your ereader maybe a new battery.
What is error 1185
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope this helps you
Sony eBook Reader PRS-900.
Hi Williammsyke,I haven't had this happen lately, but when it did occur in the past, I found that reinstalling the computer software solved the problem (or check on Sony's site for software updates). I would suggest trying that since it sounds like you've updated all of the device options already without any luck.
My Windows 7 Home Basic can not identify my Sony
http://www.userdrivers.com/Notebook-Tablet-PC/Sony-Reader-Daily-Edition-PRS-950SC-System-Update-2-0-00-11300-for-Windows-XP-Vista-7/download/
here is the link to the drivers. download and install. should work fine afterwards.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
