20 Most Recent
Canon iR5000-6000-L1 PS Ver 1.0 Questions & Answers
How to solve this e000061-0001 error
Hi
The description for this error can be found here:
Error Codes Canon iR6000 Code E061 0001
and is the same for both the IR5000 and IR6000. There is a link on this page as well to download the full service manual for the model displayed, which should enable you to solve the problem.
On the right at the top of the page you can change the error code you are looking for to get a quick reference.
Hope this is helpful, if so would you please register that with Fixya
Cheers
12/14/2018 10:15:15 AM •
Canon...
Answered
on Dec 14, 2018
Canon ir6000 giving error e225
Error code E225 on Canon 1. CIS lamp is bad.SOLUTIONS:1. Turn the power OFF and then back ON.2. Replace the CIS unit.
11/26/2016 2:11:20 PM •
Canon...
Answered
on Nov 26, 2016
Canon compute software drivers
Go to the Canon website, select your operating system, and download your driver - http://bit.ly/1G1CIhq
5/13/2015 12:27:15 AM •
Canon...
Answered
on May 13, 2015
How to change A4 display to LTR display
Go to Printers and Faxes, right click on the printer icon and select Printer Properties.
then select the paper type as LTR.
If in case you do not get the option, re-install the printer drivers.
9/9/2014 11:21:13 PM •
Canon...
Answered
on Sep 09, 2014
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Hope this helps......
4/22/2014 9:47:10 AM •
Canon...
Answered
on Apr 22, 2014
Code e225
Replace the CIS unit=FK2-2869-000
10/13/2013 10:32:43 AM •
Canon...
Answered
on Oct 13, 2013
I have a problem in a machine canon ir 5000 copier
We had lines on our copies too. The repairman fixed it easily. There is a section of glass to the left of the glass where you place your original. Most people just clean the large glass surface because this is where the paper goes. When he cleaned the smaller section, all the lines were gone.
2/1/2013 10:29:18 PM •
Canon...
Answered
on Feb 01, 2013
E0732-0001 CANON IR5000
If you are looking for the driver, please download it from
HERE. or from here http://files.canon-europe.com/files/soft36798/software/o9b2enx.zip.. this driver support Windows 32 bit operating system. This download link is for Windows 64bit operating systems (
LINK) or http://files.canon-europe.com/files/soft36808/software/o9b4enx.zipYou can also search the driver
HERE.Let me know if you have problem.Good Luck.Thanks for using FixYa.
10/29/2012 6:18:33 AM •
Canon...
Answered
on Oct 29, 2012
Error code 000804
Hi Error code 000804 is normally a cooling fan ..check the power supply cooling fan
is prob a filter has got dislodged during transport and is stopping the
fins from turning
11/8/2011 9:01:11 AM •
Canon...
Answered
on Nov 08, 2011
How to reinstall canon IR5000
I have canon IR5000 machine. The data on the HD is corupted how do I reinstall the system software
8/9/2011 9:15:34 AM •
Canon...
Answered
on Aug 09, 2011
IR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
10/19/2010 6:36:56 AM •
Canon...
Answered
on Oct 19, 2010
