20 Most Recent Microsoft MS Windows XP Professional SP2 Questions & Answers
2answers
How to view RMVB video file with windows media
well try the VLC media player
12/19/2019 9:28:06 AM • Microsoft MS... • Answered on Dec 19, 2019
2answers
I want convert ntfs to fat 32
the convertion from ntfs to fat32 will result in loss of all data in the drive (all data from desktop,my documents, installed programmes.......). You can do this using your windows disc . Just set the primary boot device to be cd-rom in the bios,boot with windows cd in drive,then the installation will guide you to the insallation of a fresh copy of windows (there you can select the required file system).it is recomended to continue with ntfs
2/23/2015 7:04:03 AM • Microsoft MS... • Answered on Feb 23, 2015
What makes a mouse to continue to freeze.
low memory and less processing speed . Try to upgrade your system
7/17/2010 5:11:04 PM • Microsoft MS... • Answered on Jul 17, 2010
How can i fixed the ntldr problem
The easiest way is to boot the computer from a Windows disk. When you get to the screen that asks if you wish to repair using the recovery console, choose that.
When you get to the c:\ prompt, type chkdsk /f
Once this runs, your computer "should" start up. If not, there are other things we can do.
7/9/2010 3:39:49 AM • Microsoft MS... • Answered on Jul 09, 2010
Disk drtive problem
clean the eye of your disk drive or try removing it and reinstalling it.
5/4/2010 5:39:32 PM • Microsoft MS... • Answered on May 04, 2010
My windows xp wont boot up past the win logo and
I have the same error message. It just won't load when you select a profile after booting up. It will boot up in Safe Mode.
4/4/2010 5:18:06 PM • Microsoft MS... • Answered on Apr 04, 2010
My home page is in French (Orange) How can I get it translated
Tools >> Internet Options >> Languages >> Language preferences
helpful link:
http://windows.microsoft.com/en-US/windows-vista/Change-your-Internet-Explorer-language-settings
3/28/2010 4:38:55 AM • Microsoft MS... • Answered on Mar 28, 2010
I want to open a Radio station in london. How can
check the the ofcom website and the prs website!
Cheers
http://www.ofcom.org.uk/consumeradvice/radio/radiobroadcast/
http://www.prsformusic.com/Pages/default.aspx
Please see my blog http://simontodd.com for IT ideas!
3/7/2010 10:33:07 PM • Microsoft MS... • Answered on Mar 07, 2010
2answers
Hello, I have a laptop Dell Latitude 600, Win XP
there are many programs for speed up and clean the registery for free
pcbooster or spotmau or windows xp manager
10/15/2009 8:34:11 PM • Microsoft MS... • Answered on Oct 15, 2009
I have a pirated Windows Xp installed in my pc but
Okay, first things first- Pirated versions of software simply ain't cool, for any number of reasons (first being that using pirated software is ILLEGAL!), but in addition, most pirated garbage has all kinds of extra junk with it, like trojans, viruses, keyloggers, etc. which may be preventing you from installing a proper OS.
If you know what kind of harddrive you have, go to the manufacturers' site and get yourself their version of disk management software (usually a self-extracting .exe file that'll write to a 3.5 floppy). Make sure you get the version applicable to your particular drive. Make the floppy, and restart your computer with the floppy in your a drive, and follow the prompts to reformat the drive (bear in mind that you're going to lose everything on the drive). Remove the floppy and shut down your computer.
Next, restart your computer and get into the bios settings, and set your boot order to read your optical drive (CD or DVD-Rom) first, save settings, put your OEM disk in the drive, and restart- You SHOULD be good to go.
Another note: If your OEM disk isn't from the manufacturer of your computer, you'll still have issues, as OEM versions are coded for particular board/hardware combinations.
Bottom line- Computer systems are becoming more and more affordable, and using pirated software only leads you down a path to problems. Reformat your harddrive and open your wallet enough to get a legitimate copy of the software you want!
10/7/2009 9:41:55 PM • Microsoft MS... • Answered on Oct 07, 2009
Making formula for in cell reference
From what I understand, you want to make a formula in MS Excel which will refer to itself. This is not possible.
You can make a target cell containing the information you need (variable, etc.), and work from there.
You can also get additional information from the Microsoft site.
Hope this helps.
6/27/2009 10:25:04 AM • Microsoft MS... • Answered on Jun 27, 2009
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
6/5/2009 6:18:00 AM • Microsoft MS... • Answered on Jun 05, 2009
Internet Explorer
These could be the possible reasons and solutions:
1. Clear temporary Internet files.
  • Start Internet Explorer 7.
  • On the Tools menu, click Delete Browsing History.
  • In the Delete Browsing History dialog box, click Delete Files.
  • Click OK to close the Internet Options dialog box.
2. Verify that the Show Pictures option has not been turned off
  • On the Tools menu, click Internet Options.
  • Click the Advanced tab, and then verify that the Show Pictures check box is selected under Multimedia.
  • Click OK.
3. Enable scripting, ActiveX controls, cookies, and Java programs
  • Click the Security tab, and then click Default Level (if it is available) for the zone that contains the Web page (for example, the Internet zone).
THIS IS FOR IE7
5/22/2009 6:11:56 AM • Microsoft MS... • Answered on May 22, 2009
Make MS-DOS Boot CD
Hi. This adress (http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html) contains a couple of ready boot discs. Just download them (.iso file) and burn them to a CD. Hope this helps.
5/22/2009 5:49:01 AM • Microsoft MS... • Answered on May 22, 2009
2answers
Xp Starttup and Shutdown
The best way to solve this is to back up your personal data to an external source such as a CD, DVD or external hard drive, then reinstall Windows XP. The most likely reason for the slow start up is missing or corrupted Windows system files.
Please let me know if you need any further assistance regarding the above info.
Best wishes,
Graemevm
5/21/2009 6:24:17 AM • Microsoft MS... • Answered on May 21, 2009
2answers
Startup Windows XP
It is possible to change your start up screen. Here is a link to the trial software necessary to do this:
http://www.softpedia.com/get/Tweak/System-Tweak/BootXP.shtml
The application is called Bootxp and can be used to change your boot screen to whatever you like.
Best wishes,
Graemevm
5/21/2009 6:23:18 AM • Microsoft MS... • Answered on May 21, 2009
Internet Explorer 7
I would guess that your default settings have changed for some reason.
the easiest way will be to uninstall IE7 and re-install it again. that will take few minutes and everything will work for you:
1. go to : http://www.microsoft.com/windows/internet-explorer/default.aspx
2. download the file and save it to your desktop
3. go to Control panel --> add/remove software--> remove IE7
4. install IE7 again
5/19/2009 3:30:57 PM • Microsoft MS... • Answered on May 19, 2009
Nlite Windows XP Pro SP2 not recognized
Dear,
You should use Nero 6 or above version. It is very easy to use.
Just create an image of original disc and then burn it on the blank disc.The copied disc will work fine, I am sure.
Please try it.....
Regards,
Rakesh Kumar
4/30/2009 9:36:08 AM • Microsoft MS... • Answered on Apr 30, 2009
Multimedia controller problem
Error code 28 indicates that the driver for multimedia controller is not installed or corrupted. Use the driver cd provided by your computer manufacturer and install the audio driver.
Revert back for any clarifications
4/9/2009 4:26:31 AM • Microsoft MS... • Answered on Apr 09, 2009
I CANT PRINT FROM OUTLOOK EXPRESS AND IE 7
Print an Email in Windows Mail or Outlook Express To print a message from Windows Mail or Outlook Express:
  • Highlight the message you want to print in its mailbox.
    • Unfortunately, you cannot select and print multiple messages at once.
  • Click the Print toolbar button.
    • Alternatively, select File | Print... from the menu or
    • hit Ctrl-P.
  • Adjust any printer settings you deem necessary.
  • Click Print.
3/31/2009 3:43:27 AM • Microsoft MS... • Answered on Mar 31, 2009
Microsoft MS Windows XP Professional SP2 Logo
28 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
pirated windows xp installed in pc but
  • Computers & Internet
