20 Most Recent
Ranger Pickups 19932010 Books Questions & Answers
I needed fuse diagram for a 2003 ford ranger pick
https://www.google.com/search?q=2003+ford+ranger+fuse+diagram&hl=en&client=firefox&hs=T7g&rls=com.yahoo:en-US:official&tbm=isch&tbo=u&source=univ&sa=X&ei=G7g9Ubf_KsvaqwGywICIDg&ved=0CDAQsAQ&biw=1400&bih=908
Wipers of my ford ranger 1999 isn't squirting water
Remove hose at part at windshield and see if some comes out,if it does then it's clogged at windshield part,tooth pick may help,or the pump is bad,follow hose to pump.line could have junk in it and glogging at the part at windshield.
Turning signial will not work on left front side i
Check to see if you have power to the bulb with a volt meter when you turn on the signal light. If not change the socket that your bulb goes into. They get dirty and rust builds up in them. I had the same problem.
The truck idle's high about 2000 rpm's until i
check and clean iac ( idle air control ). do not put in any liquid, just use a old toothbrush or similar to remove carbon and debris from valve on end of iac. do not push on valve. it will mess up setting. you can use throttle body cleaner to clean it or similar product. good-luck ! if this does not work try a n other valve from junk yard, its cheaper than a new one.
My parking brake light stays on even when
Check your BRAKE switch under the steering column, just where ur brake pedal resting on it when ur not stepping on it!
Connection might have been disconnected or the switch needs replacement!
Taah!
Diesel Pump Rotor Head 1 468 334 337
diesel Pump Rotor Head 1 468 334 337
Item Name(EH)#injector bmw 320d e46#
# head rotor ford 12 mm#
#head rotor ford 187l#
#injector chrysler voyager#
#for injector common rail delphi#
#Ultrasonic Injector Cleaning Machine
#UltraSonic Fuel Injector Cleaning
(EH)China Lutong Parts Plant is a famous manufacturer and supplier specializing in diesel engine parts.We have 30 years experience in this area.
Our aim and business policy is to give the customer a reliable quality product and service, alternative to the OE products. The parts are quality
assured to ISO9001 and are subject to regular internal and external audits ensuring that quality is the highest standard.
nicole(at)china-lutong (dot) net
Wha/tsa/pp:+86133/8690/1375
[email protected]
I have a 1996 ford windstar
They remote is for the immobiliser system. Immobilisers are designed to be VERY difficult to bypass otherwise why fit them? Your simplest solution here is to go to a car key specialist and get a new remote. Once the old one fails the car will not start at all.
