20 Most Recent
Omega Vert HD Machine VRT350 VRT 350 Juicer juice new Questions & Answers
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below: http://www.omegajuicers.com/juicers/masticating-juicers.html
Omega Juicer VSJ843 Wont Power On
It could be the fuse is bad and the cord is also bad too. The fuse inside of the juicer and the power cord will both need to be replaced.If the motor has quit working then you will have to buy another juicer.
My omega 8003 juicer will not power on
1. test for power at female end of cord? (eliminates, breaker, socket, cord, plugs, all wiring to appliance. I think this appliance is hard wired at the connection, so you may need a non-contact tester.
Juicer stuck
i have no solution thats why i am asking where i can purchase a pulp collector
Hi nothing happens when i
Hello! Welcome to FixYa!
Sir/Ma'am which specific model and type of Omega Juicer you are using? Is it Centrifugal Juicer, Pulp Ejector Juicer, Citrus Juicer or Masticating Juicer? Is there specific thing happens when you switch on it like it vibrate or something or it shows no response? and when you tried it on the outlets which problem they diagnosed for it. Have they told you the solution of the problem?
Please let me know about these so i can provide you assistance that what should you do,
I am here to help, Waiting of your response.
Thank You
My omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
The moment it is switched
It is quite possible that the motor bushes , bearings or the jar bushes are worn out as this will make the motion of the high speed motor to allow the friction to work through therby making the whole assembly to vibrate.
You need to check this by observing the shaft play, it will be very minute but is enough to cause problems.
