20 Most Recent
HEWLETT-PACKARD HEWLETT PACKARD HP COLOR LASERJET CP2025DN Duplex Unit Questions & Answers
HP Color LaserJet CP 2025dn error code 59.70
We had a persistant Error 59.70 with an HP m452DN printer, which kept up after power cycling the device. Since it's an error with the black toner developer motor, I pulled the black toner, powered up the printer, and manually checked the drum on the toner for seizure. Rotated the drum by the knob on the side to free it up, and then reinserted and printed a cleaning page. Printer works fine now.
We have a hp2025dn printer
Hello cstoddard692,
Welcome, and thank you for using FixYa!
Actually, no, you will not need to do any further purchases. The "DN" on the end of the model name, 2025dn, refers to your Duplexer and Network JetDirect card already being installed.
Your issue is in the properties of the printer. You need to right-click on the printer, enter the properties, and find the tab for "Device Settings" Near the bottom of all of the options you will see listed, you will find "Duplexer". It will probly refer to it being "Not Installed". Simply switch this to "Installed" and hit Apply, then ok.
Now, under the Printing Preferences in the General and Advanced Tabs; you should see the options for double-sided printing. Simply place a check mark in the box to enable it and set to "Flip on Long Edge".
That should resolve your issue.
Have a great day!
Need A service Manual for H P 435
You can download
here all the PDF manuals concerning the HP Color LaserJet CP2025 serie.
This serie of printer included the HP Color LaserJet CP2025DN Duplex Unit.
Hope this solution help you.
Please feel free to contact me if you have any other questions or comments about this solution.
Thank you!
I have a networked hp 2025dn printer the problem
my personal opinion is that you might have two basicproblems
1.open the lid from back of your printer, you may see a stiff film .,give aprint command and check the film rolling visually , if its broken then it mightgive you annoying sound like something's broken , but it can only be visualizedgiving a print command ,
if its really broken from edges it may give you this problem, it can be fixedby local service center ,I had this problem it cost me about
2.(clean your printer )
>Open printer
>remove the toner
> check for any piece of stapler pins or any paper or anyother waste that's stuck in between drums.
> if you have a wind blower machine blower it .
> must keep in mind to blower it in open area, causeblack particalls will make you cough, or would get dusty,
3. your toner must have ink dust at one side, shake thetoner and then insert in printer , this will help you .
I hope it helps you
Hp laserjet 5100n
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
