20 Most Recent Targus 4PORT USB 20 TRAVEL HUB ACH7405US ACH7405US Questions & Answers
So I purchased a Targus
You can download the driver from the Targus website.
Here is an alternate link
https://www.solvusoft.com/en/update/drivers/usb-hub/targus/models/
12/15/2017 3:45:36 AM • Targus 4PORT USB... • Answered on Dec 15, 2017
I plug in the 4
sometimes you have to plug a usb into these to get them to respond if this does not work try plugging it into another USB port. If this does not work than look at the wires they may have come unattached
12/17/2016 7:46:18 AM • Targus 4PORT USB... • Answered on Dec 17, 2016
Will not power my usb
Small travel hubs use power from the Notebook's USB port, the issue you are experiencing is "most likely" caused by there not being sufficient power output to allow all devices to run successfully - the following devices should be connected directly to the notebook:
* External hard drives
* Printers
If the issue occurs with Mouse, USB Key / Dongle Drives, Keyboard then the issue is either a faulty peripheral ( the mouse/ Key etc) of with the Dongle itself.
5/3/2011 1:49:58 AM • Targus 4PORT USB... • Answered on May 03, 2011
Can this be used with my home computer to rum my
This is a straight forward USB hub, allowing you to expand a sing USB port to four
USB ports. anything you normally connect to a USB port on your PC can be connected through this. The only thing to remember is that the USB port on the PC is designed to provide 500mA of current, and if you use a USB hub then the total current of all devices connected is still 500mA. If you require more power then you can buy powered USB hubs.
2/20/2011 10:16:45 PM • Targus 4PORT USB... • Answered on Feb 20, 2011
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
  1. Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
  2. Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
  3. Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
  4. Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
  5. Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
12/17/2023 11:49:21 AM • Targus Computers... • Answered on Dec 17, 2023
.Yo I have a Targus ipad keyboard case that is cracked open in the back
1. remove all screws 2. buy white glue epoxy 3. mend all broken sections 4. fix them back and screw them after they dry
8/13/2022 3:29:43 PM • Targus Computers... • Answered on Aug 13, 2022
Looking for a targus apa01 wire diagram to connect to computer
Contact Targus directly to request the wiring diagram.
10/19/2021 12:43:00 AM • Targus Computers... • Answered on Oct 19, 2021
I have a targus bluetooth speaker mid#2550913 for got the pin
Try 0000 or 1234
6/26/2020 10:14:08 PM • Targus Computers... • Answered on Jun 26, 2020
Targus BEU0564C driver
Try Snappy Driver Installer - Install and Update Drivers is Free and no Ads or Malware https://sdi-tool.org/
2/27/2019 1:15:11 PM • Targus Computers... • Answered on Feb 27, 2019
Where did i get targus presentaion USB Stick
I found one on Amazon. Wireless Presenter, ON THE WAY RF 2.4GHz Wireless Presenter Remote Presentation USB Control PowerPoint PPT Clicker. see the link below. https://www.amazon.com/Wireless-Presenter-WAY-Presentation-PowerPoint/dp/B06Y5ZGPX1/ref=sr_1_1_sspa?ie=UTF8&qid=1542643943&sr=8-1-spons&keywords=targus+presentation&psc=1 presenter-bzex1t3xi1odt41tgkzajjgr-5-0.png
11/19/2018 4:16:20 PM • Targus Computers... • Answered on Nov 19, 2018
4answers
How to install epson stylus
I have the same printer; first need install the drivers, according woth your OS (Operative System), this drivers can find and donwload from this link: printers_and_all_in_ones/Epson_Stylus_T13
Just select your OS and donwload, install the driver and follow the guide step by step.
Good luck.
11/13/2018 6:02:03 PM • Targus Computers... • Answered on Nov 13, 2018
Print from targus tablet
google targus with make model and serial and go to support/download and get user manual.pdf
9/30/2018 8:36:14 AM • Targus Computers... • Answered on Sep 30, 2018
I need user manual for Targus laser pointer model AMP01US.
ManualsLib has the User Manual for the Targus AMP01US Wireless Multimedia Presenter with Trackball here: https://www.manualslib.com/products/Targus-Amp01us-7090628.html . You can download the manual from the Download button in the upper left corner of any page after the title/table of contents page. I hope this helps. Cindy Wells
9/2/2018 10:55:06 PM • Targus Computers... • Answered on Sep 02, 2018
0answers
Targus 4PORT USB 20 TRAVEL HUB  ACH7405US ACH7405US Logo
5 questions posted
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Targus Computers & Internet
Most Popular Question
used home computer rum
  • Computers & Internet
