20 Most Recent
Konica Minolta DiMAGE 7Hi Digital Camera Questions & Answers
I have a dimage 7hi
This doesn't sound good. You could be having a problem with the lens, or with the ccd (image detector inside the camera. You can take it in to a camera repair shop and see what they think, and how much it might cost to fix it. You can also contact Konica Minolta to see how much they would charge to have it fixed. Here's their website:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Good luck, and hope this helps you.
How do I format the card when it says card error
Hello
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off.
2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
Kind
regards
Andrea
Help!!!
1. Format CF to FAT16 - no remember how many folders u may have at once
2. Set "DRIVE" to single frame
3. Set quality to FINE - RAW may take up to 10MB and u can`t take series nor UHV movie
Konica Minolta Dimage 7Hi - Faulty
It could (note I'm saying could, not is) be a bent flash card pin. If you get it, take a look inside the camera's CF card slot. If a bent pin is spotted, remove the batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Now if you get it and there's NOT a bent pin in there (say it's a missing pin, a very different story) don't come back crying here! :-)
Lcd black, but can hear the picture being taken
This is part of a known problem with the SONY image sensors that operate the lcd.
There is in fact a recall that will replace the bad componets. You need to contact SONY for repairs.
Check out this website to learn more about your problem. http://www.imaging-resource.com/badccds.html
Pleas help me get my digital camera working
Here is the link to the manual;
http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-7/dimage_7hi/D_7HI_E.pdf
and here is the link to software downloads and important product notices if you need them;
http://www.konicaminoltasupport.com/index.php?id=23&L=0
Post again if you need any more help :)
How do I clear pictures off the memory card?
The best way to remove all pictures from the memory card is to format it. This wipes all data from the card and prepares it for further use.Without knowing the model of your K-M camera I can't give you the exact procedure for formatting the card, but there should be a command somewhere in the menu system, probably under "Setup".
