20 Most Recent
Konica Minolta DiMAGE E323 Digital Camera Questions & Answers
Why does my card say card protection how do i get
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dimage E323 "system error"
remove 6 phillipscews open camera.There is a little drivemotor for the lens,next to it is a shaft activating the limit switch for lens opening and closing.Carefully spray plastic safe electronic cleaner into the opening.Now apply 3 volt to the motor reversing polarity a few times to activate the limits. Now use canned air to blow out any residue of the cleaner.This worked for me,camera working again.
OS are supported for USB
The DiMAGE E323 is compatible with Windows98/98SE/Me/2000 Professional/ XP(Home/Professional), MacOS 9.0-9.2.2/MacOS X (v10.1.3-10.1.5, v10.2.1-10.2.6).
Can images recorded by another digital camera be played on this camera?
It is possible if they support the Exif data (image data) based on DCF. However, they may not be played back, or played back as thumbnails depending on the file format, image size or data configuration in a file. Also, the audio files attached with images cannot be played on this camera. DCF = abbreviated expressions of a standard for aim at the compatibility in files between the related devices such as digital cameras. Please refer to the instruction manual of your camera (main specification - image file format) to confirm if the camera is compliant to DCF or not.
Size the recorded image file
Compression rate:2880x2160 / 2048x1536 / 1600x1200 / 640x480
Normal: 1/9 1365KB / 698KB / 432KB / 82KB
Fine : 1/6 2040KB / 1039KB / 640KB / 115KB
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames)
Recording
Alkaline batteries : Approx. 80 frames
Ni-MH batteries (2100mAh): Approx. 410 frames
CR-V3 : Approx. 720 frames
Playback
Alkaline batteries : Approx. 275 min.
Ni-MH batteries (2100mAh): Approx. 340 min.
CR-V3 : Approx. 518 min.
Language displayed
Japanese, English, German, French, Spanish, and Italian are switchable.
Zoom function
Yes. This camera has 3x optical zoom and 4x digital zoom. However digital zoom cannot be used in 2880 x 2160 size. Optical zoom: It is approximately 5.6 - 16.8 mm. (equivalent to 38 - 108 mm on 35mm film camera)
Digital zoom: It extends to 4x from telephoto end (108mm) of optical zoom.
DiMAGE E323 dimensions and weight
Dimensions: 99(W) x 62(H) x 34.5(D) mm / 3.9(W)x2.44(H)x1,36(D) inch.
Weighs: Approximately 145g, excluding battery and storage media.
