20 Most Recent Konica Minolta DiMAGE X31 Digital Camera Questions & Answers
I have a Minolta Dimage x31. It was using a small
This is a 6-year old camera. It was not designed to use SDHC cards. Your maximum is a 2gb SD card.
12/8/2010 10:50:41 AM • Konica Minolta... • Answered on Dec 08, 2010
Tells me card is locked and I don't know how is
try to remove the memory card and see if it has a read and write protect switch. If it is locked, switch it to unlock. If it doesn't work, try to format the memory card, if everything else fails you would need a new memory storage device then.
6/21/2010 11:21:00 PM • Konica Minolta... • Answered on Jun 21, 2010
2answers
My Dimage X31 Camera does not turn on even with new batteries.
Make sure that you have them installed the correct way +/- and also check that the old batteries didn't leak and cause corrosion on the battery connection tabs.
4/22/2009 4:29:06 PM • Konica Minolta... • Answered on Apr 22, 2009
Why can't I see lcd screen properly in the sun
When I can not see LCD screen when sun shines on it I use viewfinder , I think it tells you in the user Instruction manual if sun is so bright you can not see LCD use viewfinder .
12/21/2015 9:36:17 PM • Konica Minolta... • Answered on Dec 21, 2015
How do I clear pictures off the memory card?
The best way to remove all pictures from the memory card is to format it. This wipes all data from the card and prepares it for further use.Without knowing the model of your K-M camera I can't give you the exact procedure for formatting the card, but there should be a command somewhere in the menu system, probably under "Setup".
12/26/2012 9:59:07 PM • Konica Minolta... • Answered on Dec 26, 2012
How to change the time & date Backup Battery on a Konica Minolta Dimage Z2
The backup cell is rechargeable and when the main battery is reinserted and charged, it will charge the backup cell after a while.
3/4/2024 4:41:35 PM • Konica Minolta... • Answered on Mar 04, 2024
Konica Minolta Dimage Z6 working fine, but Windows 11 wont recognise it. Any ideas please?
If your Konica Minolta Dimage Z6 camera is working fine but is not being recognized by Windows 11, there are a few things you can try to troubleshoot the issue:
  1. Check the USB cable: Make sure that the USB cable you are using is properly connected to both the camera and the computer. Try using a different USB cable to see if that resolves the issue.
  2. Check the USB port: Try connecting the camera to a different USB port on your computer to see if the port is the issue. Some USB ports may not have enough power to detect the camera.
  3. Install the camera driver: If the camera did not come with a driver disc, try downloading and installing the driver from the manufacturer's website. Make sure to download the correct driver for your camera model and operating system.
  4. Restart the computer: Sometimes, restarting the computer can help to resolve issues with USB devices not being recognized.
  5. Try a different computer: If the above steps do not work, try connecting the camera to a different computer to see if the issue is with the camera or the computer.
If none of these steps resolve the issue, it is possible that there may be a hardware problem with the camera. In that case, it may be necessary to contact the manufacturer or a qualified technician for further assistance.
3/17/2023 8:12:42 PM • Konica Minolta... • Answered on Mar 17, 2023
My Konica Minolta dimage A200 has recently started draining the battery very fast. Bought new batteries but the problem persists. The camera is now almost unusable.
A circuit or wire short will need to be diagnosed with a meter or send out for repair
4/9/2021 7:30:29 PM • Konica Minolta... • Answered on Apr 09, 2021
2answers
I have a damaged LCD
Consider the following: Minolta closed their camera division in 2004, and sold the operation to Sony. That's also why the later Minolta lenses are compatible with Sony DSLRs (Minolta AF mount).
However, this meant that Minolta cameras were also automatically rendered obsolete, with no new spares being manufactured / supplied. (I know, I still own some Minolta cameras and have been down this road)
Now, I'm sure you can see how slim the chances are of getting any spares for the camera in question, especially a humble Point and Shoot.
It's time to aquire something newer (imho).
5/12/2018 4:25:13 AM • Konica Minolta... • Answered on May 12, 2018
Konica Minolta DiMAGE X31 Digital Camera Logo
10 questions posted
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
DiMAGE Konica Minolta
  • DiMAGE Konica Minolta
Most Popular Question
minolta dimage x31 using small
  • Cameras
