20 Most Recent Konica Minolta DiMAGE G400 Digital Camera Questions & Answers
0answers
0answers
My digital G400 minolta fall in a short distance, the lense moves out but no photo appears? what I do?
From the description the shutter is not working, in order to address this the lens must be taken apart to see if it can be salvaged, and there is the matter of a dimmed screen. My sense is replace the camera with a new one, cost to repair will be high something to consider when a camera specialist checks it out.
6/14/2012 8:52:21 PM • Konica Minolta... • Answered on Jun 14, 2012
Need to update driver
You're not going to see a new driver for a camera this old. But you really don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
2/22/2012 7:21:53 AM • Konica Minolta... • Answered on Feb 22, 2012
Download free drivers for minolta camera g400
easiest solution is to visit manufacturers website. all drivers should be on there to download. hope this helps
2/21/2012 7:03:05 PM • Konica Minolta... • Answered on Feb 21, 2012
0answers
What is system error MFOOC
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
9/30/2011 6:34:45 AM • Konica Minolta... • Answered on Sep 30, 2011
All of a sudden outdoor
Konica Minolta stopped producing digital consumer cameras a few years ago. As a result parts are very hard to find and it is difficult to repair these models. Unfortunately an issue like streaks on the image is usually a shutter mechanism problem and the part would need to be replaced. You'll most likely be better off buying a new camera.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
7/5/2011 3:11:58 PM • Konica Minolta... • Answered on Jul 05, 2011
Card is protected error message
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
6/27/2011 4:14:57 PM • Konica Minolta... • Answered on Jun 27, 2011
Memory full and I cannot get the camera to
You can install the driver to you PC and connect the camera.
or
If you don't have the driver or the installation process was failed, then put off the memory card from your camera into a card reader then plug in to your PC.
I hope that both or one of those way will work so you can open and copy your picture from your memory card to your PC, then you can delete copied files from your memory card (you can straight to"cut" and "paste" but I prefer "copy-paste-del" process). After cleaning some data from your memory card, you can put in again into your camera. And make sure to organize your camera to save taken pictures in memory card (not in camera memory) so you can repeat this process in the future.
Hope this help and be kind to rate please, thank you.
(^_^)
1/6/2011 4:57:04 PM • Konica Minolta... • Answered on Jan 06, 2011
THE LENS WILL NOT GO BACK SYSTEM ERROR
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 3:49:38 PM • Konica Minolta... • Answered on Sep 27, 2010
My camera tell
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
9/11/2010 5:45:06 PM • Konica Minolta... • Answered on Sep 11, 2010
I only had the Minolta DiMAGE G400 for one year
hi. go into the menu and find the reset function. reset it. this may solve the issues. j.
7/11/2010 10:25:09 PM • Konica Minolta... • Answered on Jul 11, 2010
Where can I get the CD-Rom for dimage G400
You can try :-
http://ca.konicaminolta.com/products/consumer/digital_camera/dimage/dimage-g400/index.html
Then either download the manuals you require or contact their support team.
3/14/2010 3:50:50 PM • Konica Minolta... • Answered on Mar 14, 2010
Powers up, lens doesn't move, shows error MF00C and shuts down.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/6/2010 9:21:46 PM • Konica Minolta... • Answered on Mar 06, 2010
My computer which is running a vista platform will
2/8/2010 11:36:15 PM • Konica Minolta... • Answered on Feb 08, 2010
Lens will not protrude on opening
Hi, I had the same problem.I fixed it doing the same thing as for the lens not retracting. Hop ethis helps.
Good luck.
Paul
2/7/2010 9:49:05 PM • Konica Minolta... • Answered on Feb 07, 2010
Konica Minolta DiMAGE G400 Digital Camera Logo
59 questions posted
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
DiMAGE Konica Minolta
  • DiMAGE Konica Minolta
Most Popular Question
digital g400 minolta fall in short
  • Cameras
