20 Most Recent Konica Minolta 5600HS for Maxxum Minolta TTL Flash Questions & Answers
I am looking for manual
Here is an online manual for your digital camera:
http://www.scribd.com/doc/22344755/Minolta-Maxxum-Flash-5600HS-D-Manual
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
6/3/2011 4:16:00 AM • Konica Minolta... • Answered on Jun 03, 2011
I have a Minolta 5600HS flash that I have used for
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
4/5/2010 11:44:38 AM • Konica Minolta... • Answered on Apr 05, 2010
How do i replace the hot shoe mount on a sony a200
You take it to a repair center. This is not a toaster. Its a precision instrument. A modern camera is not user serviceable. Contact Sony on their website to find out where to send it. If you are in the USA then its Precision Camera Repair. Look them up on the internet.
Again, do not attempt this yourself.
One reason is the built in flash. The charging capacitor for the flash retains its power after the camera has been shut down, and can give you one heck of a shock or fry a circuit board that falls down where it doesn't belong.
1/1/2010 3:23:06 AM • Konica Minolta... • Answered on Jan 01, 2010
I have a Minolta 5600Hs flash. It's worked great
I would not recommend you fix it yourself since several of the inside componentes are high voltage and dangerous. But, why wont the flash turn on? if the batteries are good, could it be the battery contacts on the battery door and inside the flash? If the batteries have ever corroded (even a little) then that would be the problem. Use a pencil eraser to shine up the contacts until they are bright and shiney clean. Do not use sand paper or anthing vabbrasive as that will cause the contacts to corrod more and the problem will be worse.
11/21/2009 6:20:40 AM • Konica Minolta... • Answered on Nov 21, 2009
MINOLTA DYNAX 5400 HS flashgun manual
Since Minolta quit the camera/flash biz, Ebay is your best bet for a printed copy.
To get a free pdf file, Go to KM global website.
Select Canada, as yer country.
navigate your way to downloads.
Also check the Orphan camera website.
I have a pdf for one, but I am not allowed to give it to you here.
Try the Minolta groups on Yahoo.
10/20/2009 1:13:21 AM • Konica Minolta... • Answered on Oct 20, 2009
Minolta 5600 flash on Sony A200 camera hot shoe problem
This is what you need:
http://cgi.ebay.com/TTL-Cord-Flash-Bracket-Sony-Alpha-A700-Digital-Camera_W0QQitemZ290258666395QQihZ019QQcategoryZ48515QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
it screws into the mount underneath your camera, connects via a cord to your hotshoe mount, and your flash willl then sit next to your camera mounted on this flash bracket.
6/3/2009 9:10:18 PM • Konica Minolta... • Answered on Jun 03, 2009
I need owners manual for minolta 5400hs flash
I Have one send me a email at [email protected]
5/29/2009 12:02:08 AM • Konica Minolta... • Answered on May 29, 2009
0answers
How to change the time & date Backup Battery on a Konica Minolta Dimage Z2
The backup cell is rechargeable and when the main battery is reinserted and charged, it will charge the backup cell after a while.
3/4/2024 4:41:35 PM • Konica Minolta... • Answered on Mar 04, 2024
Konica Minolta Dimage Z6 working fine, but Windows 11 wont recognise it. Any ideas please?
If your Konica Minolta Dimage Z6 camera is working fine but is not being recognized by Windows 11, there are a few things you can try to troubleshoot the issue:
  1. Check the USB cable: Make sure that the USB cable you are using is properly connected to both the camera and the computer. Try using a different USB cable to see if that resolves the issue.
  2. Check the USB port: Try connecting the camera to a different USB port on your computer to see if the port is the issue. Some USB ports may not have enough power to detect the camera.
  3. Install the camera driver: If the camera did not come with a driver disc, try downloading and installing the driver from the manufacturer's website. Make sure to download the correct driver for your camera model and operating system.
  4. Restart the computer: Sometimes, restarting the computer can help to resolve issues with USB devices not being recognized.
  5. Try a different computer: If the above steps do not work, try connecting the camera to a different computer to see if the issue is with the camera or the computer.
If none of these steps resolve the issue, it is possible that there may be a hardware problem with the camera. In that case, it may be necessary to contact the manufacturer or a qualified technician for further assistance.
3/17/2023 8:12:42 PM • Konica Minolta... • Answered on Mar 17, 2023
My Konica Minolta dimage A200 has recently started draining the battery very fast. Bought new batteries but the problem persists. The camera is now almost unusable.
A circuit or wire short will need to be diagnosed with a meter or send out for repair
4/9/2021 7:30:29 PM • Konica Minolta... • Answered on Apr 09, 2021
2answers
I have a damaged LCD
Consider the following: Minolta closed their camera division in 2004, and sold the operation to Sony. That's also why the later Minolta lenses are compatible with Sony DSLRs (Minolta AF mount).
However, this meant that Minolta cameras were also automatically rendered obsolete, with no new spares being manufactured / supplied. (I know, I still own some Minolta cameras and have been down this road)
Now, I'm sure you can see how slim the chances are of getting any spares for the camera in question, especially a humble Point and Shoot.
It's time to aquire something newer (imho).
5/12/2018 4:25:13 AM • Konica Minolta... • Answered on May 12, 2018
Screen says Card Locked..
Check your memory cards. If you are using SD cards, there is a small slide-lock on the side of card. Move the slide away from the LOCK icon, re-insert the card in the camera, being careful not to cause the slide to move again, and you should be able to use the card normally.
5/21/2016 3:55:04 PM • Konica Minolta... • Answered on May 21, 2016
Konica Minolta 5600HS for Maxxum Minolta TTL Flash Logo
10 questions posted
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Cameras
Most Popular Question
minolta 5600hs flash s worked great
  • Cameras
