20 Most Recent Breezaire WKE8000 Wine Cellar Cooling Unit Questions & Answers
How do i change out the control board to Breezaire WKE 8000
A WKE 8000 IS PROBABLY THE EASIEST UNIT TO REPLACE THE BOARD ON, REMOVE THE TOP FRONT GRILL(COLD AIR DISCHARGE) AND BOARD WILL BE RIGHT THERE BEHIND THE GRILL, USE NEEDLE NOSE PLIERS TO REMOVE WIRES FROM BOARD, MAKE SURE YOU MARK THE WIRES BEFORE YOU DISCONNECT THEM(USE BLUE TAPE WITH NUMBERS) AND TAKE A PHOTO WITH YOUR PHONE OF THE WIRES WITH THE NUMBERS ON THEM,ONCE WIRES ARE REMOVED PULL THE OLD BOARD UP AWAY FROM THE 6 PLASTIC PEGS IT IS SITTING ON AND INSTALL THE NEW WKE CONTROL BOARD(IT SHOLUD BE BLUE IN COLOR) PRESS IT ON THE PLASTIC PEGS, AND RECONNECT THE WIRES USING THE NUMBERS AS GUIDE
10/16/2012 6:31:08 PM • Breezaire... • Answered on Oct 16, 2012
0answers
0answers
Leaking water
Be the first to answer 5/25/2012 4:06:37 AM • Breezaire... • Posted on May 25, 2012Be the first to answer
I need a wiring diagram for a Breezaire WKE 8000
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
8/18/2011 10:48:03 PM • Breezaire... • Answered on Aug 18, 2011
I have the wkl6000 which
IF YOUR UNIT IS A WKL MODEL 0.6 IS AN ERROR CODE A REPLACEMENT OF THE CONTROL BOARD SHOULD SOLVE THE ISSUE
8/16/2011 6:45:16 PM • Breezaire... • Answered on Aug 16, 2011
I am trying to recharge my Breezaire WK8000 cellar
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
8/16/2011 6:41:56 PM • Breezaire... • Answered on Aug 16, 2011
How do you know if
Before you can answer that question the equipment must have clean evaporator, clean condensor, all fans working oiled and up to speed. Drain line in evaporator clean and opened. what refrigerant. let me know I can help. Thanks for choosing fixya. wally
7/29/2011 2:55:01 PM • Breezaire... • Answered on Jul 29, 2011
Model WKL 4000. Why isn't it cooling?
check see if compressor running if not check capacitors if ok bad compressor if running low freon
2/14/2021 4:35:01 AM • Breezaire... • Answered on Feb 14, 2021
2answers
Breezaire WKL 1060. System was working but had iced up. Then followed instructions to clean up and restarted. It runs for a short period of time then shuts off with an E1 error code.
ON A WKL 1060 AND FOR THAT MATTER ON ALL WKL UNITS THE E1 CODE IS NOT AN ERROR CODE ITS A FEATURE. ON INITIAL START UP OR AFTER UNPLUGGING THE UNIT FOR MORE THAN 10 MINUTES (RESETING THE BOARD) THE UNIT WILL RUN FOR 30 MINUTES AND THEN IT WILL CHECK TEMPERATURE INSIDE THE WINE ROOM, IF THE TEMPERATURE IS 70 DEGREES OR ABOVE IT WILL DISPLAY E1 AND SHUT OFF THE UNIT. YOU WILL HAVE TO RESET THE UNIT BY UNPLUGGING IT FOR NO LESS THAN 10 MINUTES TO RESTART THE UNIT, IT WILL RUN FOR ANOTHER CYCLE OF 30 MINUTES AND IT WILL RE CHECK TEMPERATURE AGAIN, IT HAS TO READ 69 OR LOWER FOR THE UNNIT TO RUN NON STOP TILL IT MEETS THE SET COOL POINT OF 55 DEGREES.
10/23/2018 2:16:44 PM • Breezaire... • Answered on Oct 23, 2018
0answers
0answers
Float settings
Be the first to answer 5/22/2014 3:47:13 AM • Breezaire... • Posted on May 22, 2014Be the first to answer
0answers
Error code AL
Be the first to answer 12/31/2013 3:21:26 AM • Breezaire... • Posted on Dec 31, 2013Be the first to answer
0answers
0answers
Breezaire WKE8000 Wine Cellar Cooling Unit Logo
8 questions posted
Top Breezaire Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Breezaire Refrigerators
Most Popular Question
need wiring diagram breezaire wke 8000
  • Refrigerators
