20 Most Recent
Breezaire WKC1060 Wine Cellar Cooling Unit Questions & Answers
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
10/17/2012 7:48:06 PM •
Breezaire...
Answered
on Oct 17, 2012
Unit is not cooling. there
UNPLUG FOR 15 MINUTES AND REPLIUG UNIT IT SHOULD RESET UNIT, DOT IS A DELAY MODE FEATURE OF THE UNIT, YOUR UNIT IS NOT A WKC IT IS A WKCE1060
8/16/2011 6:38:46 PM •
Breezaire...
Answered
on Aug 16, 2011
WK3000-7 yrs old. Stays on
Hi!!
Check your temp. settings and that the fan in the freezer/refrigerator is working, if items are working, (normal settings are about 1/2 way of the dial range). then your problem is a Refrigerant leak. When refrigerant level is low, the lines start to freeze but as soon as the compressor stops, the ice will melt. When there is a problem with the.defrost timer or the defrost coil, Ice builds up and takes up to a day with the fridge open to melt.
The repair of a leak in the system should be performed by a qualified HVAC Technician.
I suggest to call and ask how much would it be to repair the leak, then you decide if it is worth fixing or just replace it.
Good Day!!
9/26/2010 8:59:34 PM •
Breezaire...
Answered
on Sep 26, 2010
Have a Breezaire Sentinel II
If you wish for a Local Repair, tell me the Zip Code and i would try to Search for a Serviceman from our Listings.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/19/2010 4:02:32 PM •
Breezaire...
Answered
on Jan 19, 2010
Breezaire wkce 1060 does not cool my wine cabinet
I'm not familiar with your unit, but sounds like condenser problems. Check for a dirty coil on the backside or underneath the unit. Also, if it has a fan for that coil, make sure it's running when the compressor is running and that the blades are clean. Other than that, it could have developed a refrigerant leak.
9/15/2009 2:31:03 AM •
Breezaire...
Answered
on Sep 15, 2009
