20 Most Recent
Vulcan Hart VSX5G Counter Convection Steamer Questions & Answers
We have two steamer .
1 Your fill valve may be stuck open.
2 The water level control board or probes may be defective.
3 The unit is full of lime scale and interfering with the water level controls.
We purchased a used Vulcan Steamer model # VSX10GC
Please be careful
when converting appliances form natural gas to propane. Depending on the
equipment there are several changes that need to be made. You will at least
have to change burner orifices and convert or replace the gas valve. Some gas
valves are not convertible. What many people over look are changing the pilot
orifice and on some appliances like braising pans, griddles and char broilers
there is a runner tube orifice. The gas valve also needs to be adjusted to the
proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you
contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Vulcan double deep Fryer with built-in filter system model 2GR45AF the pilot light is lit, but the burner don't fire and heat the shortening
HI.
Its Bob
To fire up, you need 3 things,
Air ( with oxy) fuel and source.
First step, is to make shure, you have gas.
Without this, you will never get no were.
Second , you must purge the system to get air out of the gas line.
this is done by trying to light up the system , 4 to 8 times,
here the click is the valve opening and closing....
this will clear the system out of air and get the gas to the burder.
this will take time, 4 to 8 tries...
if you smell for any reason gas, stop, shut off the gas...
This smells like rothen eggs...
Gas is heavier then air, so it flows down to the lowest level.
there is also sensors ,switchs on this...
Read the instruction on how to purge or turn on the gas...
some have to push down hold for 5 secs, then turn..
Please work safe/
bob
My vulcan lg 300 deep fryer latch won't turn what should I do
Some fryer valves have a safety lock, usually a slide on the handle near the valve body that must be released to open the valve. Check for this first. It's very rare for a fryer valve to stick unless it was forced shut with something partially blocking it. If not, let the fryer cool completely. Dip as much oil out as possible. Then disconnect the gas line and, with help, turn the fryer upside down draining the remaining oil into a suitable container. At this point, you have little to lose. Take a large wrench or piece of pipe to get more leverage and try to force it open and free it up. Do not use so much force that you damage the kettle. If you get it free, check to see that it does not leak before putting oil back in the fryer. If it leaks or fails to come free, replace the valve.
If wires are crossed will burner work
It depends on which wires are crossed. Switching the wires on a two wire high limit, thermostat, or thermopile will not matter. The wiring on the gas valve must be correct for the fryer to work properly and safely.
