20 Most Recent Yamaha Trumpet Ytr 6335 Questions & Answers
2answers
Are there any other Yamaha model trumpets that the
Any Bb trumpet made by Yamaha should have valves that are interchangeable. A few models that might do it are:
YTR-6345GS
YTR-6335S
YTR-200AD
YTR-8335LA
These are all in the same tuning as yours, so the valves should fit without any problems. The S at the end of some models denotes a silver finish.
Hope that helps! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
1/30/2013 10:16:02 PM • Yamaha Trumpet... • Answered on Jan 30, 2013
2answers
My Yamaha YPT-240 will not turn on. I messed around with the wire for a bit and it turned on for about 3 seconds - is it permanently broke or can I get a new lead?
You should get a new power adapter. Search for the YPT-240 Power adapter. You'll need the equivalent of the Yamaha PA130 DC 12V 1.0 A adapter. The original (<$20) and third-party power adapters are available from Amazon. First, I'd check if the YPT-240 will stay on with 6 AA batteries. That will rule out any internal problems before you order a replacement power adapter. I hope this helps. Cindy Wells
3/14/2024 10:27:09 AM • Yamaha Music • Answered on Mar 14, 2024
Will a midi interface allow me to play downloaded music on a yamaha clainova 305
Yes, with some preparation. The music will have to be in a standard MIDI file format or a format that results in standard MIDI over USB output when "played" by computer software or an external sequencer. Within the software you will probably need to create a new "instrument" if there is not already a template for the CVP 305, otherwise the tracks and sub channels in the MIDI file will be patched to GM, probably not what you want to hear.
2/17/2024 11:28:18 AM • Yamaha Music • Answered on Feb 17, 2024
2answers
What is the best way to reprogram a Yamaha WX5 Ewi
Reprogramming a Yamaha WX5 Electronic Wind Instrument (EWI) typically involves adjusting settings, assigning functions to different keys, or customizing parameters to suit your preferences. Here's a general guide on how you might reprogram a Yamaha WX5:
  1. Access the Menu:
    • Turn on your Yamaha WX5.
    • Navigate through the menu options using the buttons or controls on the instrument. Refer to your WX5's user manual for specific instructions on accessing the menu.
  2. Select Parameter to Edit:
    • Once in the menu, find the parameter you want to edit. This could include things like breath sensitivity, pitch bend range, or assigned MIDI channels.
  3. Adjust Parameters:
    • Use the controls provided on the WX5 to adjust the parameters. This might involve turning knobs, pressing buttons, or using a combination of controls.
  4. Save Changes:
    • After making your adjustments, make sure to save your changes. The WX5 typically has a save or store function within the menu. Confirm the changes and save them to the instrument's memory.
  5. Refer to the Manual:
    • Consult the user manual for your specific Yamaha WX5 model. The manual will provide detailed information on navigating menus, adjusting parameters, and saving changes.
  6. Connect to a Computer:
    • Some advanced customization may require connecting your WX5 to a computer using MIDI. You can use Yamaha's dedicated software, if available, to reprogram certain parameters.
  7. Use External Sound Modules:
    • If you're using external sound modules or synthesizers, some customization may need to be done on those devices as well. Refer to the manuals for your MIDI equipment to ensure compatibility and proper configuration.
  8. Explore Advanced Settings:
    • Depending on your proficiency and the complexity of your WX5 model, you might explore more advanced settings like custom MIDI mapping or adjusting sensitivity curves.
Remember to approach reprogramming with caution, especially if you are not familiar with all the settings. Make note of the default settings before making changes, so you can revert to them if needed. Always refer to the user manual specific to your Yamaha WX5 model for accurate and detailed instructions on reprogramming and customization. If you're unsure or uncomfortable with the process, consider seeking assistance from Yamaha support or experienced professionals in electronic wind instruments.
1/22/2024 6:24:18 AM • Yamaha Music • Answered on Jan 22, 2024
Yamaha PSR-333 Keyboard. What could be the problem of psr 333 Yamaha keyboard that is displaying Yamaha only?
Try re loading the software. It's all in the user manual.
1/19/2024 7:11:25 AM • Yamaha Music • Answered on Jan 19, 2024
I have a Yamaha US 1 organ. The foot pedal broke after 25 years of service at our church. I am trying to buy 4 part #15 foot pedal replacement pedal.. Can you help
My US 1 has had four broken pedals, and now has a fifth. I called Yamaha, and they DO have washers for the pedals but not until March. It is technically what they are calling a "failed instrument." So many of the parts have failed but been successfully replaced until now. The plastic in the pedals becomes old and brittle over time, then reaches a point where it just cracks off. The MDR has been rebuilt too, but is very temperamental. It doesn't allow me to copy discs any more. I'm trying to find a used one to replace it. Any ideas? [email protected]
1/5/2024 1:18:08 PM • Yamaha Music • Answered on Jan 05, 2024
3answers
MOX6 won't turn on. When switch is pushed, it
You might have an internal fuse blown. If you are capable, open up the keyboard and visually look at the fuses. If one is blown, replace with the same amp rating. Good luck!
11/18/2023 8:25:46 PM • Yamaha Music • Answered on Nov 18, 2023
Hello I have piano Yamaha psr1100 sound of beat is ok but voice of key is not played and rubber key is ok what the problem
Seems the carbon layer under the button needs repair.
9/18/2023 2:04:53 PM • Yamaha Music • Answered on Sep 18, 2023
Yamaha PSR-S750 61-Key Digital Workstation Keyboard is just showing a logo.
Question edited for clarity. Try a Factory Reset. Try a power reset first. Disconnect from the mains plug for 15 minutes.
System Reset - Yamaha PSR-S750 Service Manual
ManualsLib https://www.manualslib.com > ... > Service manual There are two reset methods in the SYSTEM RESET display: Factory Reset and Custom Reset. ... This function lets you restore the status of the instrument to the ...
4/18/2023 6:08:53 PM • Yamaha Music • Answered on Apr 18, 2023
Electronic organ repair
4/17/2023 4:38:04 PM • Yamaha Music • Answered on Apr 17, 2023
I need a repair/service manual for a yamaha electone organ model D-2B
Sure, I can help you find the repair and service manual you need. I suggest starting by searching online through authorized Yamaha retailers or in the Yamaha archives. You can also try contacting a local Yamaha dealer for assistance.
4/10/2023 1:19:58 PM • Yamaha Music • Answered on Apr 10, 2023
I need the long ribbon that connects the keyboard to the circuit board. AND ALSO THE RUBBER CONTACTS TO THE CENTER SOUNDING STRIP. YAMAHA GHL88 X6245
Aquire the service manual and record the part number. Speak to Yamaha or one of their agents to obtain a spare part.
4/10/2023 1:16:23 PM • Yamaha Music • Answered on Apr 10, 2023
Looking for stand for Yamaha piano keyboard do you sell them
This is not a shop!
4/10/2023 1:15:46 PM • Yamaha Music • Answered on Apr 10, 2023
I just purchased a Yamaha Portatone Electronic Keyborad - WK 13700. Do you know when they were manufactured, and what they are worth today? Plus, any ida where i can get a manual for it? Thank you.
The Yamaha Portatone WK 13700 was manufactured in the early 2000s, around 2001-2002. The value of the keyboard today depends on its condition, whether it has been well-maintained or not, and its functionality. A used Yamaha Portatone WK 13700 keyboard in good condition can range in value from $100 to $300. You can try searching online marketplaces such as eBay or Craigslist to get an idea of the current market value. As for the manual, you can try contacting Yamaha directly or searching for it online. Yamaha may have a digital copy of the manual available for download on their website.
4/10/2023 12:34:29 PM • Yamaha Music • Answered on Apr 10, 2023
Yamaha Trumpet Ytr 6335 Logo
1 questions posted
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
any other yamaha model trumpets
  • Music
