20 Most Recent NEC (50019497) Projector Lamp for VT440, VT54 Questions & Answers
The projecor fell from the cieling and hit the ground
Yes you can if you have acess to a good soldering iron.mains power connectors need to be strongly bonded to earth, the circuit board and the case so make sure the joins are strong and secure. Obviously ensure the power is unplugged before commencing and be warned there can be a lot of easily broken (and expensive) glass panels in there- you can really mess things up permanently. sometimes the power inlet socket of the projector is right at the bottom of a few layers of optics, so don't be afraid to ask a professional to finish the job if it's beyond you.
Best of luck to you.
Don't forget to secure the projector to a strong timber beam in the roof!! :)
1/7/2010 12:54:53 PM • NEC (50019497)... • Answered on Jan 07, 2010
2answers
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
11/26/2009 5:08:32 PM • NEC (50019497)... • Answered on Nov 26, 2009
I have a NEC MT840 Projector. I cannot get it to
are you adjusting the slider in the front for manual focus?
8/21/2009 3:49:05 AM • NEC (50019497)... • Answered on Aug 21, 2009
Ballast Assembly Replacement
post the number on ebay see if any are availble
8/21/2009 3:48:22 AM • NEC (50019497)... • Answered on Aug 21, 2009
VT440 NEC PROJECTOR
let it cool down then remove the lamp and see if it looks shattered or burnt- if it is you have solved your problem-change lamp!
8/21/2009 3:47:29 AM • NEC (50019497)... • Answered on Aug 21, 2009
Have a problem with my nec vt 46 projektor, the
you need to change the lamp-remove the lamp and look at it if it looks black or shattered it needs to be changed
8/21/2009 3:45:44 AM • NEC (50019497)... • Answered on Aug 21, 2009
No image
try switching your input source and make sure you select S Video. Also you can try to feed a composite (RCA - Yellow Cable) into it and see if you get an image. Are you able to get an image/blank screen? Can you access the menu and see it?
8/1/2008 4:06:00 PM • NEC (50019497)... • Answered on Aug 01, 2008
2answers
NEC Projector VT440
I am a computer and electronics tech for a school district. I have worked on a number of different model projectors. The biggest problem that I see that can wear out a bulb VERY FAST is dust in the filters. When the filters get clogged with dust, the projector cannot move the proper amount of air to keep the lamp cool. These lamps run extremely hot and if not cooled properly can fail very fast. The first sign of a failing bulb is that the picture gets very dim. This is a good sign that the bulb needs to be replaced.
Another thing that can reduce the life of the bulb is leaving the projector on when it is not in use. If you are not using the projector for an extended period, shut it off. Leaving the projector in an A/V muted state does not shut down the bulb completely and can still wear on the lamp hours. These bulbs are rated for a certain number of lamp hours, so any time the projector is on, it is wearing away the hours of useable time. And at the cost of these bulbs, this can get expensive.
Most companies that sell bulbs sell the entire bulb assembly which is the bulb in an easily removeable housing that is usually made of a heat resistant plastic. One place that I use for replacement lamps is a site called my projector lamps http://www.myprojectorlamps.com. This site will sell you the entire bulb assembly for a reasonable price. If you feel confident enough and have a bit of mechanical ability, you can usually get the bulb alone at a cheaper price and replace the one in your existing housing. Bulbs for some of these can be a bit tricky to replace in the plastic housing, so check out your assembly before going and ordering just the bulb. You may want to even try getting the bulb out of the housing first to make sure you can do it. That way if you damage the housing in any way you can then order the complete assembly.
4/14/2008 3:16:28 PM • NEC (50019497)... • Answered on Apr 14, 2008
How do I turn on my P350x NEC projector and how to reset the timer?
1. To turn on your NEC P350x projector, press the power button on the top of the projector. 2. To reset the timer on your NEC P350x projector, press the Menu button on the remote control. Then navigate to the "Timer Settings" menu and select the "Reset" option.
12/27/2023 6:09:58 PM • NEC Office... • Answered on Dec 27, 2023
NEC IT3640D copier. We have a malfunction code C4101 on it. What can we do?
All here and also the Service Manual in Scribd.
C4101 error code Bizhub 350
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Apr 23, 2010 - C4101 code at power up. Description: C4101 code at power up. Solution: PROBABLE CAUSES: 1. Failed PWB-A (Mechanical CB). Missing: NEC ‎IT3640D
IT40D Series Service Manual ' PDF
Scribd https://www.scribd.com > doc They are sharp and may hurt you. Be sure not to leave the packing material inside the system. It may cause a system malfunction or a fire.
SOLVED: Error code c4101 - Konica Minolta
Fixya https://www.fixya.com > ... > Bizhub 362 Copier Oct 25, 2012 - THE COPIER DISPLAYS ERROR C4101. C -4101 Polygon motor error. Change the polygon motor ,if you can not reset the malfunction code.
8/8/2023 3:06:42 PM • NEC Office... • Answered on Aug 08, 2023
NEC projector M322X indicates light but cannot turn on
Based on the information provided, it is possible that there may be an issue with the projector's power button or internal components. It is recommended to try the following troubleshooting steps: 1. Check the power source: Ensure that the projector is properly plugged into a working power outlet and that the outlet itself is functioning correctly. 2. Reset the projector: Some projectors have a reset button or option in the settings menu. Try resetting the projector to see if this resolves the issue. 3. Check for internal issues: If the above steps do not work, there may be an issue with the projector's internal components. It is recommended to contact a professional technician or the manufacturer for further assistance. In summary, if a NEC projector indicates light when plugged into a power source but does not turn on when the power button is pressed, it may be due to issues with the power source, internal components, or other factors. Troubleshooting steps such as checking the power source and resetting the projector may help resolve the issue, but professional assistance may be required if these steps do not work.
6/21/2023 8:32:42 PM • NEC Office... • Answered on Jun 21, 2023
NEC NP PA550w - Replacing polarizing filters
If they are not physically broken, brake cleaner and cotton wool will get them clean. Don't put them back in the wrong way around!
10/19/2022 11:59:33 PM • NEC Office... • Answered on Oct 19, 2022
2answers
I have Windows 11. Is there an available driver for my NEC SuperScript 860 that will allow it to work on my PC?
Don't know if this will work as I don't run anything from Microsoft. I sue a proper OS; Linux. https://driversol.com/drivers/printers/microsoft/nec-superscript-860
8/18/2022 2:57:36 AM • NEC Office... • Answered on Aug 18, 2022
2answers
I bought a NEC NP M300W Projector and the picture was real weak and dim, so I ordered a new lamp and put it in and still the same problem.
M300w use LCX102 LCD panels Sony Lcd panel is not durable the font strokes are weak, The color of the black font is not black enough It means the lcd panel is failed there are 3 lcd panels in the projector Red Green Blue 3 lcd panels are failed you need a new whole prism block with 3 lcd panels
3/5/2022 8:07:50 PM • NEC Office... • Answered on Mar 05, 2022
I have a NEC PA521U Projector Red Lamp Light and will not turn on
I suspect the ballast (supply for the HID lamp) has failed due to an expired lamp. Probably not ecconomic to repair.
3/5/2022 8:07:47 PM • NEC Office... • Answered on Mar 05, 2022
NEC NP310 projector, can I replace the fan?
Your statement indicates'there is a fan issue'. It may just require cleaning but may need replacing. Nothing to do with the lamp, unless it has overheated and also needs replacing.
2/19/2021 4:46:34 PM • NEC Office... • Answered on Feb 19, 2021
NEC (50019497) Projector Lamp for VT440, VT54 Logo
11 questions posted
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Office Equipment & Supplies
Most Popular Question
vt440k orange power flashing red status
  • Office Equipment & Supplies
