20 Most Recent Logitech Z5400 Speaker System Questions & Answers
Can I get a replacement controller c/w 2.0 speakers for a Logitech Z3 S-0085B? Or something similar that would be compatible?
fixya doesnt sell or manufacturer products -notify manufacturer --electronic shop or online search for assistance
8/31/2023 3:08:11 PM • Logitech Audio... • Answered on Aug 31, 2023
I have the logitech docking speaker s-0329A how can i get my iphone 4 to work on it as when i put it on it says it does not support it and can i use an android phone on it through the headphone jack?
The Aux connection should work for either an iphone or android phone. That would be a good test to see if the speaker is still working. The top mounted iphone/ipod connecter can collect dirt and lint that will cause the proper connections to be made. Try cleaning these.
3/12/2023 5:39:30 PM • Logitech Audio... • Answered on Mar 12, 2023
Logitech x-540 speakers worked great with my old laptop but now I have an ASUS laptop and the light comes on on the volume controller but I get no sound and everything is hooked up correctly
Here's a link to the manual. https://www.logitech.com/assets/35723/setup-installation-guide.pdf This is important: 3. A. If you have a PC and a: • 6, 7 or 8 channel (5.1, 6.1 or 7.1) sound card: Connect all 3 colored plugs from the audio input cable to the color-coded jacks on the sound card. 1. If jacks on your soundcard are not color coded, plug the audio input as follows: • green to front L/R (or #1) • black to rear L/R (or #2) • orange to center / sub (or #3) • 4-channel sound card: Connect the green plug from the audio input cable to your sound card's front jack and the black plug to your sound card's rear jack. Do not use the orange plug. • 2-channel sound card: Connect the green plug from the audio input cable to the "line out" jack on your sound card. Do not use the black or orange plugs.
3/12/2023 5:30:36 PM • Logitech Audio... • Answered on Mar 12, 2023
How can we dismantle Logitech Laptop Speaker Z205?
If you try to open these speakers they will never work properly again. There are no screws. All the joints are stapled and glued.
3/12/2023 5:23:28 PM • Logitech Audio... • Answered on Mar 12, 2023
My logitech z523 the sound is so low and the volume knob doesnt adjust and even the led is on or the bass work
What are you connecting the speakers to?
3/12/2023 5:19:00 PM • Logitech Audio... • Answered on Mar 12, 2023
CAN I LISTEN TO MUSIC ON MY LOGITECH DEVICE
If its a speaker, YES.
3/12/2023 5:18:04 PM • Logitech Audio... • Answered on Mar 12, 2023
What is dc5v_1.5a on back of logitech speakers and what do you put in the hole
This is for a fuse. DC volts - 1.5 amps. There should be a screw on cap that retains the fuse. These are common fuses and available at most electronic stores.
3/12/2023 5:17:28 PM • Logitech Audio... • Answered on Mar 12, 2023
How can I bypass the control panel on a Logitech G51 and hook it up to my home stereo?
You can't. The control console is integrated into the system. This is a gaming speaker system meant to connect to a computer or game console.
3/12/2023 5:15:28 PM • Logitech Audio... • Answered on Mar 12, 2023
Can the logitech speaker connect to an I PHONE?
What model Logitech speaker? What model iphone?
3/12/2023 5:05:49 PM • Logitech Audio... • Answered on Mar 12, 2023
Need wiring diagram schmatics for Logitech z560
Hello I need to wiring order of this coupling. 20220820_231454-y4lbf2gajxyg1e3idvatmg4t-d-0.jpg
3/12/2023 5:02:35 PM • Logitech Audio... • Answered on Mar 12, 2023
Leftt speaker not working after new GPU
well doing that new GPU Card now has new GPU HDMIL sound channels so in sound setting change outputs to z323 not told you how the z323 wired to the PC. mine uses, FIBER optics. and never fails. the only way to lost LEFT size only is jacks not fully seated (baring hard failures , of the 323) mine is 900 series, and does fiber. (no hum fiber is king) yours has no such things. you are using RCA jack into the speaker right? NO PC told at all. mine has a custom soundcard, and can do it all, you name it, ALL. the problem is posting not tell at al what PC this is of endless vast. there are. desktops can do it all. laptops not. back of the sub has 2 RCA jacks aux input.both must be good and working back to the PC sound card. the sound card must be set up correcty and the silly (no GPU card told) card, must be output all turned off on hdmi. that is all I can do blind , I can not see what you own or what is connected or not. sorry
7/23/2022 10:32:47 AM • Logitech Audio... • Answered on Jul 23, 2022
How to connect my Logitech subwoofer to my aiwa hifi
The sub woofer is active and should not be connected to amp.
3/30/2022 4:46:48 PM • Logitech Audio... • Answered on Mar 30, 2022
Logitech Z5400 Speaker System Logo
2 questions posted
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
possible connect only logitech x230
  • Audio Players & Recorders
