20 Most Recent Sony BRAVIA XBR46HX909 46 in. 3D HDTV Questions & Answers
Connect Asus X58L laptop to sony bravia LED tv using VGA to HDMI cable
customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys.
12/5/2018 11:29:57 AM • Sony BRAVIA... • Answered on Dec 05, 2018
Sony bravia luz verde y amarilla parpadean
customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them Desafortunadamente la tarjeta madre tiene un fallo. Tendras que contactar la Sony para que te la reparen.
12/5/2018 11:29:53 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
Music overpowers voices
Need go to menu screen display and reduce bass to 1/4 level. Do not set more then 40%
12/5/2018 11:22:19 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
Reset parental code forgot current code
Refer its user manual for details.
12/5/2018 11:21:53 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
No digital channels
Your signal board could be damage. It will need to be replaced.You can get parts at www.interliquidparts.com
12/5/2018 11:20:09 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
Sony 1080 full hd on the screen a pop up says
Please understand that the TV does not have a lamp. The lamp is only available in rear projection TVs. The issue seems to be odd. I suggest that you unplug the TV for more than 5 minutes to perform a power resetting and check if that helps.
12/5/2018 11:12:54 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
My 46" SONY LED has no sound coming out now.
Hi this sounds very much like a dry or bad solder joint probably on the power supply PCB, if you have the necessary soldering skills and a magnifying glass you maybe able to fix this yourself.
The picture below shows an example of what a dry joint(s) looks like, if you are able to solder and understand the risks in taking apart your TV you could save yourself a good few bucks!
Always make sure the TV is unplugged and please be aware that voltages can still be stored even when the tv is turned off, if in any doubt or you are unsure about attempting a repair please consult a qualified TV technician.
Hope this helps
Midge.
12/5/2018 11:12:05 AM • Sony BRAVIA... • Answered on Dec 05, 2018
2answers
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
12/5/2018 11:22:53 AM • Sony XBR... • Answered on Dec 05, 2018
Green standby light
customer care support SERVICE number+1- -833'''272''''0777,,,,,,,,,,,call them I unplugged the unit from the AC outlet and after 1 minute tried again. It worked fine. Do you think that this was an isolated incident?
12/5/2018 11:21:11 AM • Sony XBR... • Answered on Dec 05, 2018
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
I have a Sony Bravia model no klv-22bx350 powers on them shuts down blinks 2times
2 red light blinks can mean a power supply problem that can be caused by a problem on the main board. An authorised Sony repair shop can fix that for you.
2/20/2024 8:03:27 AM • Sony Televison &... • Answered on Feb 20, 2024
Sony BRAVIA XBR46HX909 46 in. 3D HDTV Logo
13 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
XBR Sony
  • XBR Sony
Most Popular Question
connect asus x58l laptop sony bravia led
  • Televison & Video
