20 Most Recent
Troy bilt Super Bronco Tiller 208cc Questions & Answers
Won't start
it might be broken so you should go to the shop with it and complain
Started tiller up with one
check for spark with in a darker setting or buy a tester if no spark make sure the ground on the brake is releasing if it is replace coil
The carburettor how to adjust the air and fuel mixture on the carburettor
Find the adjustment screws on the front of the carburetor. Then Start the engine and let it warm to normal operating.
Adjust both screws equally and find the right mixture.Bring both screws up slowly and listen until the engine purrs smoothly. Any raggedness or rattling is a sign of too lean a mixture. Keep turning until you find the sweet spot.
Troy bilt bronco
Check flywheel alignment key for partial shearing causing a slight out of time situation. .
Compression check engine
should be 80 and above but should start at 60, but have low power, you may need valve, ring work
Not getting gas to my
Did you leave gas in it all winter with out stableizer in it Well you need to clean out your hole carberator or do you have a fuel shut off on this
