20 Most Recent
Goldstar DV7411N DVD Player Questions & Answers
Gold Star VC681M - recording from VHS to DVD
This device can not record from VCR to DVD locally not a DVD recorder. However you can record from this device to your computer save the file as a wma and then burn that file to a DVD and then watch the DVD on the DVD player. This player can decode wma files:
Here is a site to get the owners manual from:
http://www.lge.com/support/manual.jsp
Here is how the page looks:
No sound connection from my
the rca cables themselves could be unhealthy or the terminals in which the jack pins for rca cables are connected can also be faulty. try to use other cables and if you still do not succeed then check the terminals and correct if there is some jamming
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
