20 Most Recent
Husqvarna 7021RH 21Inch 160cc Honda GCV160 Side DischargeMulchBag Gas Po Questions & Answers
Why lawn mower doesn't pull
doesnt pull at all?
possibilities:
badly flooded - turn off fuel, remove sparkplug , drain cylinder, attempt to restart
internal damage/sized - would require dismantling to prove
hard to pull, but does turn over? probably valves way out of adjustment just due to wear.
Belt diagram
see if the wheel is locked up check to see if belt broke or rolled off pulley see if cable didnt brake has to be one of those
Honda engine rattles on mower
could be a few reasond why I had the same problem on one i used to use that was due to the fact that i had hit a metal post in the ground with blade and how ever much i tried to tighten the enging to the deck it still vibrated the locating pins and drive sharft were all bent Only answer was to trade it in
How do I put the
Hi bairboys,
Here is a link for your owner's manual: http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532430880.pdf
The instruction and belt diagram are on page 13.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Where to get rings for Husqvarna 145bt?
The problem is that the engine is a funny size at 40cc. If it was 50cc, you could get away with motorcycle rings. The normal way to size rings is by measuring the bore with an inside micrometer across left to right and then again front to back. The front to back measurement is often a little more worn. Then you order rings by diameter and thickness, Any local engineering company can do this and supply you with generic rings.
There is a different model here with rings at $25 but Jack's Small Engines is $57. My advice is get the OEM ones. You will also need to hone the bore lightly to dull the polish. Oil the new rings with 2 stroke oil when fitting them.
https://www.google.com/search?q=husqvarna+145bt+piston+rings+size
