20 Most Recent Hyundai ImageQuest DVD 320 A DVD Player Questions & Answers
0answers
Movie playing from flash drive (memory stick) stop after 75-80%
Formatting your memory stick will make it workable,if still problem persists than check by changing memory stick.
11/14/2013 5:59:13 PM • Hyundai... • Answered on Nov 14, 2013
0answers
I have a 320A and
Be the first to answer 8/15/2011 3:10:17 PM • Hyundai... • Posted on Aug 15, 2011Be the first to answer
0answers
Problem with Hyundai DVD 320a
Turned out to be oxidisation on the battery terminal in the remote--scraped it off with point of a penknife to ensure good electrical contact and hey presto!!
2/23/2010 10:51:07 AM • Hyundai... • Answered on Feb 23, 2010
My Hyundai DVD player plays
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
3/17/2008 2:07:16 PM • Hyundai... • Answered on Mar 17, 2008
2answers
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
12/30/2021 3:30:50 AM • Hyundai... • Answered on Dec 30, 2021
2answers
Removing child lock on a 37cm hyundai tv without a remote
You can reset and eliminate the lock on some televisions without the remote, using a few tactics. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television.
4/18/2021 4:54:59 PM • Hyundai... • Answered on Apr 18, 2021
Tv hyundai chunghop rm-309es
And your question is ....................................
12/21/2020 10:13:33 AM • Hyundai... • Answered on Dec 21, 2020
Which remote used in HY2120PF Hyundai tv
Yes this model seen in image
12/9/2020 9:46:35 AM • Hyundai... • Answered on Dec 09, 2020
My Hyundai CRT TV MODEL NO co290xtu not is good condition and not have number tell me what number eht should apply please tell which number
Timr for new tv...its wearing out..will cost more to fix then new
8/15/2020 4:44:45 AM • Hyundai... • Answered on Aug 15, 2020
Hi! I need to know how do you remove key lock without remote in the Hyundai TV?
You need the factory key.
7/10/2019 11:25:44 PM • Hyundai... • Answered on Jul 10, 2019
I need Hyundai HAD 296 DVD Player user manual
not
1/23/2019 2:55:06 PM • Hyundai... • Answered on Jan 23, 2019
Hyundai lcd tv HY2240FHF DOUBLE IMAGE PROBLEM.. Solution please?tell me remte factory mode?
It seems to be the fault with its main digital board. [Vertical synchronization problem]. Anyway, try a factory reset. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
12/21/2018 5:21:38 PM • Hyundai... • Answered on Dec 21, 2018
Hyundai ImageQuest DVD 320 A DVD Player Logo
Popular Tags
13 questions posted
Top Hyundai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hyundai Televison & Video
Most Popular Question
problem hyundai dvd 320a
  • Televison & Video
