20 Most Recent Acer H5360 3D Video Projector 3D Questions & Answers
0answers
Acer H5360
Be the first to answer 5/7/2014 3:20:57 AM • Acer H5360 3D... • Posted on May 07, 2014Be the first to answer
0answers
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
2/14/2014 7:14:07 PM • Acer H5360 3D... • Answered on Feb 14, 2014
0answers
When I tried to switch
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
1/14/2011 4:27:52 PM • Acer H5360 3D... • Answered on Jan 14, 2011
Acer H7530D Projector. Hello, It does not work more than a couple of minutes. The failure log indicates System voltage = 70 or 120.
There is nothing online for that error. It sounds like your mains voltage is very low. https://www.google.com/search?q=Acer+H7530D+error+System+voltage+70+or+120 Service Manual
ACER H7530D PROJECTOR SERVICE MANUAL
ManualsLib https://www.manualslib.com > ... > H7530D Series View and Download Acer H7530D ... Page 3 H7530/H7530D Comparison List Models Parts ... Turning off (cooling completed) Error (thermal failure) Error (fan failure) ... ..
4/20/2024 6:50:35 PM • Acer Office... • Answered 2 days ago
Acer DLP projector x112. Do not turn on, fan stop, power button blinking red/blue.. please help
I had the same problem with my acer x112 , and after checking everything i found out that the problem was the Color Wheel (not necessarily being broken) , it looked new but it was the problem , hope this helps
2/13/2024 5:17:47 PM • Acer Office... • Answered on Feb 13, 2024
2answers
Acer aspire es 15 boot device missing
Great Information sharing .. I am very happy to read this article .. thanks for giving us go through info.Fantastic nice. I appreciate this post.Controle d'acces Maroc
10/5/2022 4:53:16 PM • Acer Office... • Answered on Oct 05, 2022
2answers
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:Canon waste ink tank problem.1. Change the waste ink absorber2. Reset waste ink tank counterGo to the service menu;1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.NEXT2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.NEXT3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode. NEXT4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.NEXTEach time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.NEXTHit 4 times for waste ink counter reset.The number of the Reset button pressing LED 0 time ... Green Power off1 time ... Orange Service pattern print 2 times ... Green EEPROM print 3 times ... Orange EEPROM reset (EEPROM reset)4 times ... Green Waste ink counter reset On the end press POWER button to exit .FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
4/12/2021 12:37:51 PM • Acer Office... • Answered on Apr 12, 2021
Acer H5360 3D Video Projector 3D Logo
17 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Office Equipment & Supplies
Most Popular Question
when tried switch
  • Office Equipment & Supplies
