20 Most Recent
Pentax PZ-70 QD 35mm SLR Camera Questions & Answers
I have not used my
Are your battery contacts clean ? ? Can you open the film area and see if the mirror is up ? If the mirror is up, then you have problems. The camera did not go throught it's shutter program and the mirror has not been released to go down. Major repair that is way more expensive then a replacement camera. Same with the battery, something inside is not turning off (completing the shutter function) You can go with film or digital as the Pentax lenses work with both. If you change to Pentax (Ricoh ownes it now) digital, the old film flashes will not work. Need a newer digital Pentax flash for a Pentax digital camera.
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Camera will not auto focus
Take the lens off and rotate the focus ring, it should turn very easily with little gear noise.Try a different AF Pentax lens that you know is good.
I'm sure the lens is binding, take the lens to a camera repair shop for an estimate cost to repair.
Flash on all time in auto
Please, which camera model? Are we talking about the external flash or one built in? If it is built in the camera may think there is not enough light thus setting the flash to fire. That is what auto does, it takes all the decisions away from the camera operator.
11/28/2016 2:46:07 AM •
Pentax...
Answered
on Nov 28, 2016
