20 Most Recent Pentax MX 35mm SLR Camera Questions & Answers
manual
0answers
Hi, The side of the photo came out to be blacked
The camera needs a professional service. If you're lucky the fault is just due to gummed-up, dried-out, lubricant films but if luck is against you you'll need a new shutter assembly (highly likely). Spare shutter assemblies are not easy yo come by, so if the repairer tells you that the shutter is broken you may be better to look for another camera.
35mm SLR's are mostly worthless or nearly so these days except for a few professional grade models, so getting a replacement is not difficult if you're prepared to accept different makes/models.
8/8/2010 12:16:34 AM • Pentax MX 35mm... • Answered on Aug 08, 2010
Samsung S760 Digital Camera having stripes on the
Do you get the same problem when displaying pictures taken BEFORE the fault occurred? If not, then the camera has a failed imaging sensor and the only fix is to repair it (very expensive, but may be covered by warranty) or to replace the camera.
As your camera is not very old then it's worth contacting Samsung even if the warranty has expired.
5/15/2010 2:03:16 PM • Pentax MX 35mm... • Answered on May 15, 2010
How to fix this problem then?
What's the problem?
5/10/2010 5:55:18 PM • Pentax MX 35mm... • Answered on May 10, 2010
Flash out of sync with camera release?
MX-Pentex camera,flash problem, select flash synchro....X NOT M, THAT WILL DO.
3/27/2010 3:21:56 PM • Pentax MX 35mm... • Answered on Mar 27, 2010
Pentax MX Mirror Stuck In Up Position
This is a result of the linkage from the shutter release button being out of adjustment. It is a mechanical fault that can be repaired very easily.
8/18/2008 2:57:54 AM • Pentax MX 35mm... • Answered on Aug 18, 2008
Hi there, I just got myself a K1000 Pentax camera, as a gift. I'm not a collector nor photographer, I just wanted to know more about this camera its value and if one can just keep it as a collectors item. I noticed its different from all the ones I've seen so far, it has no sahai LOGO like the others.. It is fairly new... Kindly advise accordingly.
You have yourself a camera with pedigree and it would be a shame not to put a few rolls of film through it before you decide whether to continue to use it, store it as a collectible or sell it on. Using a manual film camera is interesting and rewarding and can be fun - it is an experience no one should miss. Like learning to drive, at first there seems too many things to think of but with the help of a little reading most people soon master the basics. There is plenty of information online - see link below... https://www.google.com/search?q=K1000+Pentax+camera&rlz=1C1CAFB_enGB673GB676&oq=K1000+Pentax+camera&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 Have fun!
9/12/2019 11:49:28 PM • Pentax... • Answered on Sep 12, 2019
Pentax mz-50 counter wont advance stays on 1
Probably means the film has not loaded correctly.
10/26/2018 11:35:38 PM • Pentax... • Answered on Oct 26, 2018
Welches Baujahr ist die Kamera Pentax K1000 mit Seriennr.6764915
Parlez Anglais, s'il vous plait.
1/27/2018 10:38:45 PM • Pentax... • Answered on Jan 27, 2018
Pentax k1000 light meter issue
Try replacing the battery, or else use a separate meter.
10/24/2017 10:16:34 PM • Pentax... • Answered on Oct 24, 2017
Why don't they just download what you ask? they give all but what you ask. I want the simple operating instrusions for Pentax SLR camera
Who, exactly, are 'they' ? There are many models of Pentax SLR camera, both film and digital, and there is a different manual pertaining to the care and operation of each of these. If you go to the Pentax Service Centre relevant to your place of residence, all the available manuals will probably be there. If the one that you require is not available, you may find it by doing a Google search for the make and model, followed by the word Manual.
1/24/2017 11:57:12 PM • Pentax... • Answered on Jan 24, 2017
Pentax spotmatic f
Eric Hendrickson: http://www.pentaxs.com/index.html
11/28/2016 3:17:57 AM • Pentax... • Answered on Nov 28, 2016
Repair pentax clip on exposure meter?
Contact Eric Hendrickson, the Pentax repair person: http://www.pentaxs.com/index.html or http://www.pentaxcamerarepair.com/
11/28/2016 2:53:04 AM • Pentax... • Answered on Nov 28, 2016
Flash on all time in auto
Please, which camera model? Are we talking about the external flash or one built in? If it is built in the camera may think there is not enough light thus setting the flash to fire. That is what auto does, it takes all the decisions away from the camera operator.
11/28/2016 2:46:07 AM • Pentax... • Answered on Nov 28, 2016
I have a pentax zx-60 that is showing an error message o_ _ _ _ with an E on top of that. I'm not sure what it means or how to fix it. I tried reloading the film and it doesn't seem to advance.
I think the 'o____' is intended as a pictorial representation of a roll of 35mm film, the 'E' signifying an error in loading it. Not used this particular Pentax model myself, but some of them have a slot in the take-up spool where the 'tongue' of the film should be inserted - is that the case with yours ?
1/5/2016 10:57:08 PM • Pentax... • Answered on Jan 05, 2016
What film does a Pentax Z50P take?
It is designed to use 35 mm film DX coded from 25 through 5000. Film can be slide film, B&W, and color negative film.
1/5/2016 4:34:04 PM • Pentax... • Answered on Jan 05, 2016
Pentax super program great condition and well
Yes, put the film in and it will work. Best regards, BIll
10/25/2014 7:04:55 AM • Pentax... • Answered on Oct 25, 2014
0answers
Loud beeping picture
Be the first to answer 3/25/2014 11:10:47 PM • Pentax... • Posted on Mar 25, 2014Be the first to answer
Photography Logo
10 questions posted
Top Pentax Photography Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pentax Photography Expert? Answer questions, earn points and help others
View Most Popular
Pentax Photography
  • Pentax Photography
Most Popular Question
side photo came out blacked
  • Photography
