20 Most Recent
Sharp AQUOS 52in. LE820 LED LCD HDTV Questions & Answers
Sharp LC52LE820X not turning on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size....
No sound
Make sure the sound isn't muted or sent to the optical output. If that isn't it then the main board on the TV is bad.
Bolt size for wall mount to fit new sharp LC60SQ15U
It will be a metric bolt. They very from model # to model #. Don't get them too long as they could go past the insert and into a PC board!
If you were too Google your model # you may just fine what Metric bolt it would take to mount it. Any good hardware store would have the correct metric bolt or screw for you.
How to adjust for best picture a Sharp Aquos
This sounds like a setting that can be adjusted. What I like about some of the Sharp televisions is the av mode setting (preset brightness/contrast adjustments). I am not looking at the manual for this model so I'm not sure if this is an option on this television. However with this being a high end aquos model there is free assistance available to you. You can register your television at aquos advantage and chat live with an aquos advisor at Sharp's Midwest Corporate Headquarters. The agent may advise you to call in if your television need and Industry Initialization because you have to be talked through it. I advise the chat reps initially because when you call you aren't able to speak with the Midwest Corporate Sharp reps unless your call is being escalated.
http://www.aquosadvantage.com
