20 Most Recent LG 32LD450 32 In. LCD HDTV Questions & Answers
Where is the IR sensor in the LG lcd tv?
Mine is a question mine is a question my cat peed on my sensor on front of my RC a LG TV how do I replace the sensor the remote still works I've been turning it on and off manually it works with functioning it manually on the television
12/22/2021 5:58:00 PM • LG 32LD450 32... • Answered on Dec 22, 2021
2answers
When I hook up DVD player to 32inch LG television there is no color on the TV it plays in black and white. Why?
first check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green) then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
2/14/2020 8:55:03 AM • LG 32LD450 32... • Answered on Feb 14, 2020
Cracked screen on lg lcd tv small crack 6in up an
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
7/22/2017 5:49:04 AM • LG 32LD450 32... • Answered on Jul 22, 2017
I have a 32inch tv but cant find headphones jackplug
In some models there would me no headphone jack. May it only have RCA audio out and optical out. If you wish to get some details about television repair then check the following link http://electro-medical.blogspot.com/
8/22/2016 2:37:21 PM • LG 32LD450 32... • Answered on Aug 22, 2016
I dont know how to take child lock off a LG TV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
8/5/2015 4:57:15 PM • LG 32LD450 32... • Answered on Aug 05, 2015
How do i get black n white to color
Where are the pictures coming from? Off-air, cable, DVD, VTR, computer, etc?
2/13/2015 9:17:24 AM • LG 32LD450 32... • Answered on Feb 13, 2015
WHAT FORMAT TO PLAY FILMS WITH A STICK ON LG TV
Plug stick in and go to multi media mode and select from there.
2/4/2015 9:31:17 PM • LG 32LD450 32... • Answered on Feb 04, 2015
The tv was giving as a gift in 2012. So I believe that I put the right model in. I was watching the tv and went to change the channel, when I noticed that the box with the channel number looked differ
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
10/21/2014 5:19:24 PM • LG 32LD450 32... • Answered on Oct 21, 2014
TV LG 29 gambar hilang hanya suara
tv lg hidup suara y ada tpi gak jelas
2/5/2014 7:44:51 AM • LG 32LD450 32... • Answered on Feb 05, 2014
2answers
LG 32LD450 i have audio but no video
Having only sound that means the inverter is bad (darfo) but switching off means also power unit.
11/8/2013 10:12:53 PM • LG 32LD450 32... • Answered on Nov 08, 2013
0answers
Tesco technika tv problems
How many times this power light flashes at one time switch on? Count it. These flashes are fault indications, and are called blinking codes. From the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.Blinking codes to many brand TVs are given in detail.
10/26/2013 6:07:04 AM • LG 32LD450 32... • Answered on Oct 26, 2013
Lg 32ld450 backlight flickering
Check its back light inverter board.
7/13/2013 12:59:12 PM • LG 32LD450 32... • Answered on Jul 13, 2013
2answers
Television turns on with sound but the screen
My TV had soon, no picture, but backlight on.The connection of the 12V line on the input board, comming in from the supply board and going to the display controller board was gone. I soldered a wire from some spot close to the incoming connector to the outgoing connector. Tried to upload nice pics, but this unfortunatly did not work, Rgds Hans Driessen, Netherlands
4/16/2013 9:13:47 PM • LG 32LD450 32... • Answered on Apr 16, 2013
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
3/14/2013 3:53:16 PM • LG 32LD450 32... • Answered on Mar 14, 2013
LG 32LD450 TV is completely dead, power supply with blown fuse on primary, how to fix?
Unless you have electronics repair experience, you will need to replace the power supply. If you do have some repair experience, I would check for any shorted diodes, bridge rectifier, switching mosfet, or a cap on the primary side. Replacing the fuse will not solve your problem.
2/14/2013 9:35:37 PM • LG 32LD450 32... • Answered on Feb 14, 2013
LG 32LD450 32 In. LCD HDTV Logo
74 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
32inch tv but find headphones jackplug
  • Televison & Video
