20 Most Recent
Klein Electronics Netrome Security Black Box 8Channel 4Cam Surveillance System Questions & Answers
I cant open a port
I may have a solution for you. I had the same kind of problems when I
upgraded the NS840 Security Blackbox Main Program from 2.0.0 to 3.0.1.
From reading in other places I really don't think the 3.0.1 software
works at all as far as being able to connect to your system remotely.
Something about the engineers sabotaging the software before they went
out of business. Luckily I still have the 2.0.0 software that I
downloaded last year. So I uninstalled the 3.0.1 and installed the old
2.0.0 and guess what? It works as advertised! You'll need to download
and unzip the program installation file here:
http://dl.dropbox.com/u/389704/ns840_2.0.0_setup.rar
1/27/2022 12:37:47 AM •
Klein...
Answered
on Jan 27, 2022
I have a netrome black
The reason your cameras image is not coming up is simply because the camera is not properly installed on your system and it might also not be on.
First, ensure the camera is properly turned on and does not have any fault.
Then you check the connections made during the installation of the camera.
Since it is a pc based security surveillance DVR system, when you connect the camera on it, it will appear as a hardware, then you have to install the camera as a new hardware. It will require a driver for it, so ensure the driver is available to be able to complete the installation.
Then if your box is receiving access for you to view your images from a central unit, then the unit have to be checked and secured that it is working properly, then you will be able to view your images.
Rerun the installation of the cameras on the box, then you check the main server that gives you access to view the images and ensure it is properly working, then your camera image will show up once again.
Take care
7/7/2010 6:54:12 PM •
Klein...
Answered
on Jul 07, 2010
