20 Most Recent
Pentax Optio S5i Digital Camera Questions & Answers
Black screen
Was the camera turned off, it must be turned on and set to USB to PC in settings menu.
Memory card error
Yes you can have dammaged the contacts in the memory card holder.
The some or all contacts could be bend, or even the switch (feeler notch) can be pusshed in or broken.
It is difficult to explain, that is why I also put a picture inhere.
You should use a light, and a magnifying glass to look in your camera.
The picture is from a memory card reader, but in your camera it should look the same. You can see nine contacts, and to the left on the picture you can see they look like a triangle. All contacts should look like thatand not one is allowed to be bend or have a dent.
When you look in the memory slot, to the right (not on the picture) you should see a little notch. That is the notch that reads the lock switch. Telling the camera the card is locked or unlocked.
If that part is missing, or broken, or inside the camera that switch is dammaged, your camera will keep telling you there is a card error.
Waht could you do?
If one of the nine contacts is down, toy could try to get it up again, perhaps with a small needle. But please don't open the camera. You could do even more damage, if you are not skilled in that. If you can't fix it, contact a pentax certified repair centre and ask them what it will cost and how long it will take to repair.
Success
I have got a Pentax
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
I have have misplaced the
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
How do I make the date appear printed on the
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
My system is not supporting
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
When Iturn it on the screen go blank and say card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Digetal carara card lack
I have lost the cd software for the pentax optio
Picasa.
