20 Most Recent Mitsubishi HS-U760 S-VHS VCR Questions & Answers
i had this model once upon a time. the only way i can think of is to try a mini screwdriver to push in the tab on the vhs tape. maybe then it will move. i had to have mine repaired when my aunt did it to mine, 20 yrs ago.
Mitsubishi... | Answered on Nov 08, 2014
You will need to rotate the gears manually with power cut off to get the vcr to return to the "unloaded" position.
Its fairly simple, find the motor and rotate the gear its connected to into a direction, if noting happens try the other direction, look for locks / switches that might be preventing it from moving if its still stuck.
Once on the unloaded position, plug it in and see if the unit works properly by loading a casette.
Mitsubishi... | Answered on Sep 11, 2011
Take the top of the VCR off and remove it manually. If you don't do this you risk ruining the tape.
Mitsubishi... | Answered on May 03, 2011
Well it's a firmware/software problem in your VHS VCR, you need to upgrade the firmware of your VCR to set the correct date, your VCR firmware not support hire date from 2009. You can please follow the below link to update the firmware -
http://global.mitsubishielectric.com/
Please post comments for more help or information........
Good Luck!!
Thanks
Mitsubishi... | Answered on Mar 22, 2010
Check the little drive pulley underneath the mech. It is very common for this to crack or break and not drive the takeup reel.
Mitsubishi... | Answered on Dec 31, 2007
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Mitsubishi... | Answered on May 20, 2007
If the status LED shows a consistent green light it means that the power is on, on the TV. ... If the status LED is blinking yellow, that means the lamp cover is open. If the status LED is blinking red and then blinks yellow, that means you will need to follow that code to find the problem with the TV.Aug 14, 2013
www.youtube.com > watch
Mitsubishi DLP TV Repair - TV is Blinking - How to Identify ...
Mitsubishi... | Answered 3 days ago
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
Mitsubishi... | Answered on Jan 13, 2020
TRY MITSUBISHI WEBSITE , FIXYA DOES NOT HAVE SUCH A THING OR GOOGLE
Mitsubishi... | Answered on Jan 10, 2020
The main problem is that you have an antique dinosaur that is well past its sell by date.
Here is an answer, but the age is the problem. An 86" Ultra HD 4K flat screen set would greatly improve your viewing enjoyment, though not the effect on your pocket!
https://techlore.com/forum/thread/21148/mitsubishi-ws-65313-will-not-come
Mitsubishi... | Answered on Jan 06, 2020
Televison & Video Logo
Popular Tags
14 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
tape ejects just after insertion
  • Televison & Video
