20 Most Recent
Troy-Bilt 32cc 4Cycle Backpack Blower Questions & Answers
Impeller removal
Since the impeller is mounted on the crankshaft and the crankshaft is part of the engine...you're going to have to hold the engine still while you remove it. Do this by removing the engine's spark plug...turning the engine to where the piston is down near bottom of cylynder and stick a length of clean, soft rope or cord in the cylinder. Then, when you try to take the impeller off, the piston will compress the rope into the head (not hurting anything) locking up the engine and allowing you to do the removal.
Ohv motor, has compression but
If there is a simple fix for your problem, it lies in checking valve lash. Any other problem means going into the engine to find. I hope this is helpful for you.
Where do i find parts list
I use Partstree.com online, if you have the money you can buy the software Smart Parts. But Partstree.com works great and its free.
