20 Most Recent Mitsubishi VS-60707 60" Rear Projection Television Questions & Answers
0answers
How to turn on tv
Hello, try holding the power button for 5 seconds and see if it will come on, otherwise try a universal remote programmed to a mitsubishi tv. If it still won't come on it might have a problem in the power supply....tks
11/8/2013 3:38:16 AM • Mitsubishi... • Answered on Nov 08, 2013
Replacement bulb for mitsubishi VS-60705 rear projection tv
The set does not use a bulb, it is a CRT type set which means it has instead 3 picture tubes, a red,green, and blue.In order to try to help what is this set doing and not doing?
12/18/2012 1:55:01 PM • Mitsubishi... • Answered on Dec 18, 2012
Why wont this model stay powered on
I spent 4hr this morning trying to fix my Samsung t.v. I replaced the bulb, cleaned entire insides of t.v., checked if both fans were running, yes, checked for any corrosion or disconnects on boards/wires the best I could, I read several internet sites an kept checking what was suggested, then I found this one, I disconnected the blue & white sensor wire from top connector(right above the bulb casing). I put one end of a piece of wire in each of the holes -2 holes, it didn't work.. I tried several times...I took my piece of wire out and plugged it back into the sensor, then I unplugged the blue and white from bottom connector, this had 3 holes.. I separated one side of my 1 piece of wire (rope type) into 3 and inserted (snugly) into coupling and my tv is now working fine. I had to try this a couple times and discovered that I didn't have my wire pushed in snuggly. I will replace temp sensor, still need to figure out if I need to replace top or bottom panel, I'm guessing the bottom panel ?????? The standby light and bulb light are both off now, yay. I have a large Samsung t.v. I think 52" that I purchased from Circuit City around 5 yrs ago, model # Hl85086W. The problem I was having; Standby Light was on when I'd turn the t.v. on, would hear a low Beeping Noise from back of tv, the Lamp Light would come on I could hear the t.v. would try to turn on and in seconds the t.v. would just Shut Off, Both Lights would stay on, I'd unplug and plug back in and try again and get the exact same thing, Both Lights would come on/ stay on, t.v. would try to turn on and Automatically Shut Off. Thank you krimi !!!, for taking the time a year ago to post this. Very Grateful! Robin from Indiana I hope this helps someone else.
9/8/2012 7:03:42 PM • Mitsubishi... • Answered on Sep 08, 2012
Lamp light occasionally lights up red and then off
You can try reseat the lamp or replace.
Go to
http://support.mitsubishi-tv.com/troubleshooting
select
TV Does Not Have Picture/Video follow the stpes If the answer is helpful, rate my answers
9/27/2011 2:40:57 AM • Mitsubishi... • Answered on Sep 27, 2011
3answers
Shuts off itself
I presume when you say it shuts itself off you mean it doesn`t actually come on, It goes to Standby, (Red light). If this is the case, It will probably be the power supply being turned off (Protection mode) by the microprocessor. Have you fitted extension loudspeakers with bad or loose connections? This was a common fault where customers made a bad job of connecting external speakers. I had this once with one set where the customer had a parrot which bit through the cable to the surround sound speakers. Try disconnecting all external connections first, If this doesn`t work, you have fitted speakers and there were taped joints in your wiring, you may have damaged the sound output chip. Other than that, you need an engineer. All modern electronic equipment including TV`s have an inbuilt safety feature to prevent the set from setting fire. It does this by having the computer which controls all the various functions (Including standby) permanently monitor all the voltages within the set. If a voltage is or goes low, possibly indicating a short circuit, the micro detects this and puts the set into standby. Some sets cycle or keep repeating the process of trying to get the set on and then gives up after a certain amount of cycles if the fault does not clear. A good example of this is when there is a very bright screen, the micro could shut the set off thinking the power supply is getting low. Basically what I`m saying is, it`s a workshop job with engineer if non of the fore-mentioned faults exists. Ian
9/23/2011 7:50:17 PM • Mitsubishi... • Answered on Sep 23, 2011
Picture is blurry like the
Your TV is out of focus. It is difficult to mention the whole procedure of fixing of blurred picture in VS-60707. It is a very long procedure & requires some instruments for adjustment. To make it easy for you please visit the following link & download 11 files. Although you see the download for VS-45607, the service manual is also for VS-60707. http://www.eserviceinfo.com/download.php?fileid=32177
First three files are archived in .rar format & rest are schematic diagrams in pdf formats. After extracting files from the first three files go to page no. 35 & adjust the focus accordingly
8/13/2011 4:10:53 PM • Mitsubishi... • Answered on Aug 13, 2011
Model vs60707 projection tv. used
You will need to replace the STK ICs,they are Big Black ICs and will have Part Number on them STK392-570.
Mats Electronics has Parts 1-800-628-1118
If you are unable to Solder you can ship board for repair to PTS 1-800-844-7871
6/29/2011 4:19:02 AM • Mitsubishi... • Answered on Jun 29, 2011
Mitsubishi Model VS-60607 has convergence problem
Caps wont cause this...check the picos and resistors...or get a repair kit from sites like www.tvrepairkits.com
4/15/2011 6:40:46 PM • Mitsubishi... • Answered on Apr 15, 2011
Main power supply failur, how
Try website like Tvrepairworld.com to buy a refurbish power supply board for the replacement or u have all the tools and know basic electronic and soldering buy a capacitor kit,they put together and replaced those dying capacitors.Capacitors are dying are alway bulging up or puffing up on it tops.
3/15/2011 4:53:48 AM • Mitsubishi... • Answered on Mar 15, 2011
When first turn on, picture jumps up and down for
There is very little that can be done for this. It is a problem that occurs to all rear projection televisions sooner or later.
3/2/2011 9:43:33 PM • Mitsubishi... • Answered on Mar 02, 2011
TV click on and off.When
The green crt is dawning to much current, and that is why the TV is shutting down, if you remove the speaker cover, there is a focus block, that has six controls, on it three are for red blue, and green screen voltages, if you turn green down where the retrace lines go away, the TV should stay on, it is not worth fixing, you would be better off getting a new LCD.
2/11/2011 5:14:03 PM • Mitsubishi... • Answered on Feb 11, 2011
It will only go up to chanel 13 before the picture
the tuner is bad, the tuner is broken up into different bands and that is what is bad. You can put you tv on 3 or 4 and use a VCR, or a other device has a tuner that will save you money.
12/3/2010 5:32:51 AM • Mitsubishi... • Answered on Dec 03, 2010
I have a mitsubishi vs60707, the tv works great
Most of the time Poor Solder connections will be the problem try resoldering the power supply board/deflection board and resolder the STK ICs. while your in the set Look for bad Capacitors
they will be vented or puffed up on top.
11/13/2010 11:28:50 PM • Mitsubishi... • Answered on Nov 13, 2010
Mitsubishi tv vs 60707 fuse keeps blowing
1. unplug from the wall
2. cut off the end of the power cord
3. splice the plug from an extension cord
4. tape it up real good
5. try again
10/24/2010 11:14:38 PM • Mitsubishi... • Answered on Oct 24, 2010
My Mitsubishi VS70707 70 turns
There are two things to look at; One is any sign of Glycol leaking, I can tell you what and how to look at that.
Also, do the self check this set should have (2000) model---when it turns off on its own press both menu and input buttons on front of set for longer than 5 seconds and release both.
Power light should blink two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
A added thought would be it may be a bad solder connection somewhere in the set--chassis would have to come out to see.
1,2 error code is no error detected
I need to know if you find a error code and what it is.
If all this information has told you something you do not know rate this solution as very helpful as I do this here for free.
SD TECH
8/22/2010 3:29:31 AM • Mitsubishi... • Answered on Aug 22, 2010
Mitsubishi VS-60707 60" Rear Projection Television Logo
99 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
lamp light occasionally lights up red
  • Televison & Video
