20 Most Recent Mitsubishi VS-6055 60" Rear Projection Television Questions & Answers
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Mitsubishi... | Answered on Mar 11, 2018
Use a keyboard though usb port or take to cable provider.
Mitsubishi... | Answered on Jan 20, 2014
Everything pluged in correctly?
If so the Are you hitting the correct button?
Also what kind of multi-switch do you have? and Is that plugged in correctly
Mitsubishi... | Answered on Dec 19, 2013
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi... | Answered on Apr 30, 2010
It seems that your unit has some sort of Thernmal problem or a problem that is shutting down the Power Supply section to the Video side of things.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Mitsubishi... | Answered on Jan 21, 2010
Yes,because the 60' it expensive,worth repairing.It will cost u $500 parts and labors.Any big screen tv tech.will able to repar it.
Mitsubishi... | Answered on Nov 10, 2009
Call for warenty service tell them it ur convergence is about to die.Must replaced the whole convergence board or the ICS.
check q570 if shorted replace it,also regulator ic401 goes bad along with c402 100mf/50volt electrolytic cap
Mitsubishi... | Answered on Sep 01, 2009
every rear projection tv has a projection bulb at the back yours is blown it will cost about $300-400 new zealand dollar to get a new one just buy a new tv preferably high definition lcd-plasma.
Mitsubishi... | Answered on Aug 01, 2009
Call a good TV Tech and tell him the problem is the convergence amp IC's are bad and need replacing. This should not cost over $325
Mitsubishi... | Answered on Jul 31, 2009
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Mitsubishi... | Answered on Jul 07, 2009
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
Mitsubishi... | Answered on May 29, 2009
Is the a mitsubishi or hitachi tv?
Mitsubishi... | Answered on Dec 13, 2007
What is the problem? And I have heard a lot in my rime but magnetized dust??? You did not really say what the problem you are having.
Mitsubishi... | Answered on Jun 30, 2007
Those three Knobs were the focus or screen controls . your problem may be dust and dirt on the lens or the tubes could be getting soft. It could also be a convergence trouble and thats very common in these sets . a picture would be nice see where your problem lies BUT let me warm you down there where you were plying and turning those little knobs is about 32000 volts!!did you know this ? A tv set is not something to experiment with as it could kill ya. Unless you have technical background in electronics I would call a servicer to assist you. Good Luck
Mitsubishi... | Answered on May 26, 2006
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Mitsubishi... | Answered on Nov 14, 2019
Televison & Video Logo
19 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
vs 6055 hear click but wont turn
  • Televison & Video
