20 Most Recent
Yard Machines MTD Gold 20 HP Lawn Tractor 13AL771T004 Questions & Answers
Tried takinf the machine out
Hi, if you can't push the mower there is a short lever on the right hand side of the diff that the brake pedal is attached to, make sure it is not seized forward. If you can push the mower, start the mower and with it in neutral, select top speed, fully release the clutch/brake pedal, push the pedal hard forward again then select any gear and release the pedal again. This resetsthe vari-speed pulley. If none of this works check that the rear drive belt idler pulley arm is free. Hope this helps, regards Phil.
Gas mixing with oil
first, there is a solenoid under the carburetor, that may not be working, the wire may be off or not getting power. second, the needle in the fuel bowl may be stuck open, it's not shutting off the fuel. the carburetor may need to be taken apart and cleaned.
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
How do i lock blade so i can un screw the bolt. I
I use a piece of 2x4 . Tip mower onto it's left side, stand 2x4 between deck and blade and remove bolt. You will need to use your leg to keep mower from rolling back. This is just a simple and inexpensive way. You may also buy a special tool to hold the blade while you remove the bolt.
GOOD LUCK>
I need to change oil
Hi, the hydrostatic drive if it runs one is non serviceable, basically its sealed for life. If it runs a transaxle its filled with semi fluid grease that can be changed but only by taking apart the transaxle. Hope this helps, regards Phil.
My mtd yard machine has develabed a jurking motion
need to replace clutch pulley this is easy if you are strong enough put it up on safe blocks rear in the air take a proper wrench put it on the nut take a 1-1/4 pvc pipe slide it over the wrench for leverage this triples leverage put a long screw driver in so the pully wont turn and turn the nut replace with new clutch pulley and belt and watch youre mower pull like new.
Runs but when u engadge the blades it dies
I would try bypassing the safety switch on the mower at the bottom of the blade control stick. It's meant to prevent starting the motor with the blades engaged but it or another safety switch can be bad. You may have one for reverse, the seat and brake.
