20 Most Recent Yard Machines MTD Gold 185 HP Lawn Tractor 13AJ771S004 Questions & Answers
I have a Briggs & Stratton 2 cylinder motor Model # 42A707-125201. Runs fine at high speed with the choke off, but it will not idle smoothly unless the choke is partially on (about 2/3). I rebui
The fact the choke must be 2/3 applied to obtain a smooth idle indicates not enough fuel is being supplied by the carb at idle speed. Applying the choke richens the air/fuel ratio. I suggest you revisit the carb idle air/fuel jets, air passages and any adjustments as well as checking for intake air leaks.
9/15/2017 6:16:37 PM • Yard Machines... • Answered on Sep 15, 2017
Drove without deck something went bang and I found a big spring on the ground
it hooks to the rear of the deck and the bracket on the transmission. i just took this picture. i have three the same way. 20170328_184320-pltjqezfsw5iwiqw0t4o4crq-4-0.jpg
3/28/2017 10:54:55 PM • Yard Machines... • Answered on Mar 28, 2017
MTD GOLD LAWN TRACTOR WHEN ENGAGE PTO AND LOWER DECK . SLOWS DOWN TURNING BELT SLIPING
Belt is worn out and needs replacing or maybe the jockey tensioner is not operating on the belt hard enough to prevent slippage. If its all in good condition get a good DIYer or mechanic to have a look. If not its down to your local garden machinery shop.
4/27/2015 9:49:40 PM • Yard Machines... • Answered on Apr 27, 2015
My yard machine rideing tractor will run good for 20minutes then shut off then it wont start again till it cools down
Loosen the gas cap and try again. Many times the ethanol gas clogs the Vents on the gas tanks
8/8/2014 8:45:18 PM • Yard Machines... • Answered on Aug 08, 2014
My 95 yard machine stays engaged in gear while
Outdoor Power Equipment Parts Use the Part Finder Tool from MTD and it will, the variable pulleys and belts need to be uncoupled, maybe try depressing the pedal a little (ON FLAT GROUND) park brake disengaged.
4/13/2014 3:13:23 PM • Yard Machines... • Answered on Apr 13, 2014
Mower stalls when blades are engaged
have you changed the gas?
5/20/2012 6:23:23 PM • Yard Machines... • Answered on May 20, 2012
Need wirig schematic fot white
I found a web site with your info and more, like the entire parts and operating manual, all free!!
http://lawnandgarden.manualsonline.com/manuals/mfg/bolens/696.html?idRes=11384702
Go to page 34 for the schematic. John
9/13/2011 12:15:21 AM • Yard Machines... • Answered on Sep 13, 2011
2answers
The rear drive belt jumps off. New belt, all
bad clutch pulley change it out
7/5/2011 10:32:14 PM • Yard Machines... • Answered on Jul 05, 2011
My lawn machine does not crank. the started was
Does it crank at all? was the starter removed then tested? It could be the engine is frozen or the battery is dead
6/7/2011 1:54:18 AM • Yard Machines... • Answered on Jun 07, 2011
Was mowing just stopped
First check 4 things.
Check the gas tank for fuel (I know it sounds silly)
Change the spark plug
Clean or replace the air filter
Try charging the battery (you can also try to jump it just like you would with a car).
Let me know if none of these things work and try to give me more details about what happens when you try to start it.
6/7/2011 1:51:42 AM • Yard Machines... • Answered on Jun 07, 2011
I HAVE A 1994 MTD 18HP BRIGGS WITH MOD
The tractor has a variable speed pulley for the 1-6 gears. You will want to check the top pulley on the shaft that is in the center of your tractor between the engine and transaxle. you may have broke the spring or adjuster.
5/4/2011 12:39:37 PM • Yard Machines... • Answered on May 04, 2011
Need spindle assemblies for a 2000 vintage, 600
Go to partstree.com and enter the info it asks for IE: Mtd mod #13aj771s004 then follow what it asks for.
its worth a try
5/1/2011 2:31:30 AM • Yard Machines... • Answered on May 01, 2011
0answers
My MTD Yard Machine Lawn Tractor suddenly chokes
need to remove float bowl and clean it and pull the jet in ctr out and clean it also, there should be fine small holes in it you barely see sometimes and if it has a rollover solenoid ( electrical solenoid in float bowl clean it as well ) so that ir actully moves up and down as you cycle key from off to on. also check your fuel filter strainer in carb , its a little screen most of the time in carb base on top part, lots of time this will partially plug up also and of course check your needle and seat while you are there! should take care of your fuel problem. If you have an external fuel pump I would also check to make sure it is pumping by pulling hose off carb and rolling eng. over, should squirt gas out.....good luck
4/16/2011 12:28:33 AM • Yard Machines... • Answered on Apr 16, 2011
Yard Machines MTD Gold 185 HP Lawn Tractor 13AJ771S004 Logo
36 questions posted
Top Yard Machines Garden Experts
john h
Jay Finke
Jay Finke
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Yard Machines Garden
Most Popular Question
drove without deck something went bang
  • Garden
