20 Most Recent
Toro 20360 eCycler 20Inch 36Volt Cordless Electric BaggingMulching Lawn Mower Questions & Answers
I have an e-Cycler model
Sounds like it may be coming from your pull rope assy. The older mowers use to stick making a high pitch squealing sound start there.
My Toro is self propelled
First take the cover off .Then tighten drive cable see if it is loose if it is replace belt .If not sometimes drive cables will stretch to the limit of breaking.
When it starts in makes
The first thing I would do is to look under the deck and see if the blade is hitting up against what I call a ring wall. This ring wall is in almost all mowers wether electric or gas. I believe it,s designed to keep the cut grass from clumping up under the deck and not discharging out the shoot. Sometimes grass, twigs, rocks, etc. get caught behind this wall PUSHING the wall out towards the blade. The blade in turn starts hitting the wall making the sound you are hearing.
First removed any grass from behind the wall, second take a hammer and tap the wall back to were it should be. Rotate the blade buy hand to see if their is clearance, if so you should be ready to mow again. GOOD LUCK.
Hi, I would like to know what is the typical compression value of a Kohler 16HP singel cylinder engine?
Yes, decompression lowers cylinder pressure during low rpm while cranking. If you're concerned with compression, you need to do a leakdown test. Inexpensive (~$30) units are available through numerous eVendors. The leakdown test provides a metered volume of air that is translated and displayed on a pressure gauge simply labeled high (excessive leakage), moderate, or low (nominal leakage).
It's an L-head engine and once they get a few hundred hours run time, the valves wear into the hard seat, lash goes to zero, and they become hard to start. You can check valve lash by removing the crankcase breather (two screws). If lash is near zero, time for a valve job. Plenty of how to videos on the web. If it's easy start, just low power then less likely a valve lash issue.
There are many things that cause low power. Bad fuel, water in fuel (fuel bowl), fouled carburetor, poor spark, fouled plug, improper plug gap, wrong plug, weak ignition module.
9/12/2023 10:24:23 AM •
Toro Garden
Answered
on Sep 12, 2023
Toro riding mower stopped moving
If you have no forward, no reverse but the motor is still running normally the most likely reason for this is the main drive belt. This connects the motor to the transmission. If it stretches, breaks or drops off the drive pulleys you will lose all movement.
8/21/2023 3:49:43 PM •
Toro Garden
Answered
on Aug 21, 2023
I have an electric Toro 1500 Power Curve snow blower and it makes a high pitch squeal when I turn on the blower. Possible bearing issue?
Yes, a high-pitched squeal coming from your electric snow blower when you turn on the blower could indicate a bearing issue. The blower motor is typically equipped with bearings to reduce friction and allow the motor to run smoothly. Over time, these bearings can wear out or become damaged, resulting in a squealing or grinding noise.
If you suspect a bearing issue, it's important to have your snow blower inspected and repaired by a qualified technician or service center. Attempting to repair the snow blower on your own could be dangerous and may cause further damage to the machine.
3/9/2023 3:02:46 PM •
Toro Garden
Answered
on Mar 09, 2023
