20 Most Recent
Mitsubishi VS-50603 50" Rear Projection Television Questions & Answers
What channel for dvd
What input do you have your DVD hooked into? That would be the input that you want the TV on.
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
12/31/2012 10:23:33 PM •
Mitsubishi...
Answered
on Dec 31, 2012
Mitsubishi VS-50603
We had a power
The model indicated is a 1996 model and if you have a working Mitsubishi remote for it I would suggest you do the hard reset.
With the set on hit Menu, 1,3,7,0 and enter. It will take you to the hidden Option menu and on the older sets you will see OPTION, OR RESET ETC, YOU HIGHLIGHT IT WITH THE REMOTE AND HIT ENTER.
The set if you do it correctly should shut off and come back on channel three in the air band. If all your inputs are back you will have to change it to the cable band and auto program all the channels.
Let me know if you have questions and also if it resolved the problem.
The idea with the reset is that if power is lost the set may be confused and reset restores all settings to factory original for when the set was new in the box.
SD TECH
12/17/2011 12:18:58 AM •
Mitsubishi...
Answered
on Dec 17, 2011
Mitsubishi VS-50603 50 in. Rear Projection can i replace the mirror myself
First of all you need to check with the nearest service dealership for the availability of the mirror and the cost of the unit. Normally the cost from such dealerships will include to an extend the replacement cost and so it will be wise to have it done in the first case than to set it up and watch a distorted image if the aligment is not proper as the fall could also have shifted the alignment.
Convergence has gone bad.
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Here is an example photo....
I keep getting a blank
there are 2 tuners in a rear projection tv. maybe the main tuner is faulty or the tuner's associated circuit has problem. if there is no signal these tv are programmed to turn the power off/stand by.
