20 Most Recent Mitsubishi VS-50501 50" Rear Projection Television Questions & Answers
Mitsubishi HD 1080 wont turn on now
You most likely have a blown fuse and its not very hard to change it.I'll try my best to walk you through it.Pictures have been added to make it  simple.First  remove all the panel screws 1.3f3f5df.jpg
10/17/2018 8:01:01 PM • Mitsubishi... • Answered on Oct 17, 2018
0answers
2answers
I have a Mitsubishi VS-A50, I turn the power on
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. IC8C01 and 02> 267P141030 HIC; STK392-110. These parts are the most common part to fail in this model. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Good Luck, Big Irish.
3/16/2014 10:02:51 PM • Mitsubishi... • Answered on Mar 16, 2014
0answers
Where are the bulbs
In the back closer to the bottom you will a round access panel thats held on with 1 or 2 screws
3/26/2013 3:23:57 PM • Mitsubishi... • Answered on Mar 26, 2013
3answers
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
9/7/2012 5:28:56 PM • Mitsubishi... • Answered on Sep 07, 2012
2answers
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
11/6/2011 8:55:49 PM • Mitsubishi... • Answered on Nov 06, 2011
My Mitsubishi VS50501A Rear Projection TV turns on then off!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
10/3/2011 5:46:56 PM • Mitsubishi... • Answered on Oct 03, 2011
When I turn on the
It definitely sounds like it's time to have a TV repair man come check it out, or you will have to bring your TV into a TV repair shop. If you are familiar with working on TV's and have the proper equipment and electrical knowledge, you may be able to take apart the TV yourself and check for damaged capacitors, or boards that need to be replaced. I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
8/3/2011 1:32:49 AM • Mitsubishi... • Answered on Aug 03, 2011
I have a Mitsubishi vs 50501 50. The picture would
there is probably quite a few "dry joints" that needs re soldering in the power supply section.
This should solve your problems rather than buying a new one.
Good luck and Thanks for using fixya.
G.
6/14/2011 3:08:40 AM • Mitsubishi... • Answered on Jun 14, 2011
I need a new Lamp.
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
8/18/2010 3:36:20 PM • Mitsubishi... • Answered on Aug 18, 2010
Intermitent audio if you jiggle TV sound comes on for a while
I would be looking for broken solder points on the underside of the signal board. Touch up with an iron and fresh solder. Trace the speaker wires to the plug on the board for a good starting point. If no obvious cracks look in immediate vicinity. Goodluck.
7/6/2010 4:48:44 PM • Mitsubishi... • Answered on Jul 06, 2010
Part number for replacement bulb on model vs50501
Google to Encompass Parts Distribution and type in model number 1-800-638-3328
5/30/2010 10:24:08 PM • Mitsubishi... • Answered on May 30, 2010
No picture sound is good
no picture but have sound
5/30/2010 9:02:45 PM • Mitsubishi... • Answered on May 30, 2010
Picture turns on but is cloudy screen, it glows
Yes,ur tv have crts coolants problems,it dead.Need it crts coolants replacement.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a crt coolants replacement kit and follow the tutor dvd instructions to rejuvenate ur crts by replacing the crts coolants.
5/13/2010 3:58:52 AM • Mitsubishi... • Answered on May 13, 2010
WS-55909 convergence problem turns now into F9A04 Fuse issue
I had this happen on my WS55909 about 2 years ago. I dont remember what the circuit id's for the fuses were, but out of 6 fuses on the middle board, the two in the middle were blown. I traced the circuit schematic and found that only the convergence IC could cause these fuses to blow. It sounds like you already put in a new convergence IC (the one with the big-*** heat-sink which probably also needs a fan) but you need to make sure all those fuses on that board are still good. After I replaced that IC, my TV still didn't work. I went and double checked for continuity of all the fuses on that board and one was blown (after checking all of them and replacing the IC). Replaced it and the TV has worked ever since. Total repair cost was 23 bucks. Professionals recommended that I would be better off just buying a LCD TV than fixing my rear projection TV, but I still dont think you can get one of those as big as 55" for only 23 bucks! ****. BTW, mitsubishi would probably tell you otherwise, but you don't have to use those "littlefuse" fuses. I soldered in a fuse-holder for a glass fuse of the same value (5amp 125v in my case) that can be purchased at radio shack. A fuse is a fuse. My TV never burst into flames.
4/9/2010 7:32:51 AM • Mitsubishi... • Answered on Apr 09, 2010
Mitsubishi VS-50501A convergence problem. The
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
4/8/2010 3:52:42 PM • Mitsubishi... • Answered on Apr 08, 2010
Televison & Video Logo
72 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
ws 55909 convergence problem turns now
  • Televison & Video
