20 Most Recent
Pentax 645N Medium Format Camera Questions & Answers
Pentax 645 reset code
Remove the battery for 20mins, replace the battery then go to the camera's menu to set the Date & Time.
When I turn on my camera the blinking icon for the
Some batteries can emit caustic fumes when discharging heavily that can attack battery contacts in the camera.
Try using a pencil eraser to scrub any metallic contacts you can reach in the camera and the battery terminals too.
Hi, my batteries in the
Hello qpray... I suspect that the voltage in those new lithium batteries is too high for your camera. Check your manual and see what batteries are recommended. I think once you get different batteries your problem will be solved.
Joe
Thanks for choosing Fixya!
Removing the top cover on my pentax 645n
The Pentax 645N is not a modular camera it has interchangeable lenses and uses film inserts. Removing the "top cover" should only be done by an accomplished repair person. I doubt anyone here would talk you through the procegure of dismantling a 645n. The Pentax 645 series of cameras is unlike a Mamiya, Hasselblad or Bronica which are modular cameras.
My film did not expose on recent shoot with my
The problem here is withint the lens/shutter, over time when not in use the shutter can get stuck into place and not open at all thus causing a under exposed or over exposed shot, what needs to take place is a camera shop will need to go in and fix the shutter. More then likely you will get off scott free with a $35 repair bill respectivly, if it comes out to more then it might nto be worth it for you depending on how your value your camera.
There is no home remedy to this but to hae a local expert have a look, Thanks. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Flash on all time in auto
Please, which camera model? Are we talking about the external flash or one built in? If it is built in the camera may think there is not enough light thus setting the flash to fire. That is what auto does, it takes all the decisions away from the camera operator.
11/28/2016 2:46:07 AM •
Pentax...
Answered
on Nov 28, 2016
