20 Most Recent Mitsubishi VS-60705 60" Rear Projection Television Questions & Answers
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Mitsubishi... | Answered on Sep 22, 2014
Try to turn it on if that works then its your cable box
Mitsubishi... | Answered on Jul 31, 2013
0150, 0019, 0093, 0178 Try out these codes
if your remote only takes 3 digit codes then remove the leading 0 from the codes.
Mitsubishi... | Answered on Jun 26, 2011
Sounds like you have a swollen cap in your horizontal hold circuit. Look at your board closely, and I am sure you will find one that is bulging on the top. Just replace with the same value.
Mitsubishi... | Answered on May 16, 2011
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service technician...click this link for service center
good luck hope this helps!
Mitsubishi... | Answered on Feb 07, 2011
rolls over when turned on.
Mitsubishi... | Answered on Sep 10, 2010
Your TV has a convergence board problem which is very common with these types of TV's even on other brands. The fix for this is by replacing two identical components (IC's) which usually have part# STKxxx-xxx. I attached a picture of what these IC's look like. But before replacing these IC's technicians check small components called resistors and pico fuses which are located around these IC's. They also check for loose or cold solder connections. The repair has to be done by a qualified technician because there are parts inside your TV that still hold dangerous amount of voltage even if it's unplugged from the wall outlet. If you are doing the repair on this TV, just let me know so I can give you more details.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mitsubishi... | Answered on Jul 02, 2010
there is a format button on the mits remote, does this solve the issue? if not it can be cable box settings
Mitsubishi... | Answered on Jun 12, 2010
The board inside where the cord attached may have cracked.
Mitsubishi... | Answered on May 21, 2010
Mitsubishi VS-60705 60" Rear Projection Television Logo
60 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
need codes program universal
  • Televison & Video
