20 Most Recent
Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television Questions & Answers
When I turn it on
Major parts burns.Deflection circuitries must be tested.Must get an estimate from the tv Tech. to trouble shoot and repair.This can't out of the blue,just replaced parts.
Picture color is starting to go- what is this
The tv have problems mis alignment any colors R,G,B the tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK covergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost $300-350 for parts and labors.
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
The audio on my Mitsubishi model WS-55413 just
was to little info .... is it on all inputs, if you turn up the sound all teh way do you hear hissing from the speakers....
have you reset you cable box i go out on at less one call a mounth that no sound is the cable box
My 55413 flashes from black screen to normal. It
Howdy,
The control buttons may be getting stuck. Try this:
1. Remove front speaker grill
2. Disconnect the two cables that are sticking out of the top of the inner cover. The TV will still work with remote. If that helps replace switches, control board not available. Part Number 432P109010 quanity 9.
Hope this helps, big IRISH.
