20 Most Recent Mitsubishi WS-65819 TV Questions & Answers
0answers
0answers
My medallion Mitsubishi TV goes from color to green and blue. What can I do to fix it. My model # is WS-65819
CRT base card circuit fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
11/2/2016 7:52:26 AM • Mitsubishi... • Answered on Nov 02, 2016
When did Mitsubishi t.v.'s come out
What is its model number? Gopakumar Gopalan Google
5/25/2014 7:02:41 PM • Mitsubishi... • Answered on May 25, 2014
Scrambled Picture using WII
ck aspect ratio
4/21/2014 2:18:54 PM • Mitsubishi... • Answered on Apr 21, 2014
Screen getting darker and color will not adjust
THIS LOT FAULT AJUSTMENT YOU ARE ELECTRONICS PERSON TAKE 25 W SOLDERING IRON RESOLDERING TO CRT NICK BORAD OR AJUST ON LOT, WATCH BELOW VIDEOS NOTE:DONT TOUCH LOT ON SUPPLY DONT TOUCH LOT&CRT LINKING PLACE WITH OR WITH OUT SUPPLY SEE :LOT(LINE OUT PUT TARASFORMER) IMAGE ON GOOGLE 7a34b048-427d-46b5-ae43-b45ed19b8828.jpg
3/24/2014 11:31:35 AM • Mitsubishi... • Answered on Mar 24, 2014
Will not turn on
If the green power light comes on for a few seconds at turn on and goes out do the self check this set has(I will be here on and off for a while):when light goes out on the front of the set press and hold BOTH the menu and input (input can be labeled source on some models) for at least five seconds and release both buttons.Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.Let me know what error code if any is found and I will direct you.Note that if you have removed power from the set that will clear the error code and give you a 1,2 error which of course is no error--you have to plug set up and try again to turn it on and do the self check when it fails.SD TECH12_11_2012_1_13_06_am.jpg
11/17/2013 7:45:15 PM • Mitsubishi... • Answered on Nov 17, 2013
Please help MyTV won't power on!
It just blew it's power supply. There could be a fuse or reset inside but not likely. It likely needs a voltage rectifier, voltage regulator, or a diode or a resistor, perhaps an IC. Find a factory authorized technician (they have schematics and oscilloscopes)
10/28/2013 5:52:46 PM • Mitsubishi... • Answered on Oct 28, 2013
Mitsubishi Medallion WS-65819 wont turn on. Code 2-2
The power supply regulator section circuit inside should be troubleshooted.
3/29/2013 8:32:52 AM • Mitsubishi... • Answered on Mar 29, 2013
The projected image is larger than the s
Based on the model number first thing to do is with original remote look for a aspect button.Also look to see if set does this with tuner and any rear inputs as well.
11/8/2012 4:29:27 PM • Mitsubishi... • Answered on Nov 08, 2012
I have a 65inch mitsubisihi and having convergence
Here is a youtube video I found that was quite helpful to repair my WS-65819 this weekend: http://www.youtube.com/watch?v=63TbxQaNkVoThere is a part 2 that deals specifically with the soldering of the chips. Hope this helps
10/1/2012 6:47:09 PM • Mitsubishi... • Answered on Oct 01, 2012
TV won't turn on.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 775 posts to different brand TVs now.
9/19/2012 11:48:15 AM • Mitsubishi... • Answered on Sep 19, 2012
2answers
I have a Mitsubishi WS-65819.
Turn the set on, then when it shuts down, press the INPUT and MENU buttons (may be DEVICE and MENU, depending on the model) on the front panel together and hold them down for at least 6 seconds. This should cause the front LED to flash a 2 digit code. If it flashes once, then twice, then pauses and repeats, it means that the TV's computer
didn't detect a problem. I'm expecting you will get a 2 flash, then another 2 flash code.
Let me know, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/13/2012 5:57:50 PM • Mitsubishi... • Answered on Sep 13, 2012
2answers
Push power button and it
To determine what your problem is:
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know
SDTECH
8/5/2012 3:37:25 PM • Mitsubishi... • Answered on Aug 05, 2012
Power on problem
1) test the outlet wall plug a desk lamp for to see if word, if does goto1a) test the power cord2) test the main switch for open or defective3)go to the power supply see if the blown fuse replace or c.breaker reset.4) if the problem persist, see for short in diode, transformer, filter, coil,rectifier.see the block diagramGod bless you8_1_2012_7_29_49_am.gif
8/3/2012 7:33:42 AM • Mitsubishi... • Answered on Aug 03, 2012
Mitsubishi WS-65819 TV Logo
114 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
please help mytv power
  • Televison & Video
